Toymods » Tech & Conversions » AE82 4AC to 20V 4AGE
Hunty
AE82 4AC to 20V 4AGE Sun, 18 May 2003 14:48 Go to next message
Is there anyone out there that has done this conversion?
If so what things will i need if i buy a half cut 20valve and an EFI Fuel tank, im also going to upgrade the rear brakes to disks apart from fitting original twin cam rear brakes which are rare as hens teeth what would be a suitable replacement? the other thing is what should i change ie belts and stuff on the 20valve when i swap it over. I was thinking i should change the clutch but should i change the timing belt aswell?
Also what do you guys think is the easiest way to get the engines in and out of the cars? Lift the chasis up and pull the engine out from underneath or pull the engine out of the top?
Cheers for any help
BansheeBuzz
Gold Coast
Re: AE82 4AC to 20V 4AGE Sun, 18 May 2003 20:44 Go to previous message
usually your better dropping it out the bottom but sometimes not possible.
Do the timing belt for safe measures but the clutch i would leave - you may get another 100000k's out of it
Previous Topic:1JZ Variants
Next Topic:Cheap Chip +20HP 4 Celica?
Current Time: Fri Oct 16 00:03:43 UTC 2026
Total time taken to generate the page: 0.063401937484741 seconds
