Toymods » Tech & Conversions » Gauges - Should I bother?
krayzie
Gauges - Should I bother? Sun, 18 May 2003 16:05 Go to next message
At the moment Im making a custom dash for my sprinter and before I start fibreglassing I can mould in some gauges.
My car is N/A and is going to stay that way. What gauges should I put in and well lets face it should I even bother?
BansheeBuzz
Gold Coast
Re: Gauges - Should I bother? Sun, 18 May 2003 20:30 Go to previous messageGo to next message
Fuel, Temp, Oil press, Voltmeter The last 2 really aren't needed and you would probable be better off running a light
Jason
Re: Gauges - Should I bother? Mon, 19 May 2003 00:48 Go to previous messageGo to next message
And a fully sik shift light so you remember to change gears Laughing
benmeyer
Re: Gauges - Should I bother? Mon, 19 May 2003 02:23 Go to previous messageGo to next message
Yeah.a nice big halogen
toycelica77
bris
Re: Gauges - Should I bother? Mon, 19 May 2003 02:45 Go to previous messageGo to next message
unless your concern that your engine is gonna piss out oil and water at any given moment i would worry about gauges
you really only need oil pressure, tacho, and water temp:S
Flem
cambo
Re: Gauges - Should I bother? Tue, 20 May 2003 10:25 Go to previous messageGo to next message
Has anybody forgotten a speedometer?( for the tacho find a brand new mini 02' model and use the tacho out of the mini it would go with the shift light Very Happy )
[Updated on: Tue, 20 May 2003 10:26]
Re: Gauges - Should I bother? Tue, 20 May 2003 10:59 Go to previous messageGo to next message
when I saw the new mini I nearly hurled
biggest ricer tacho ever, plus it's off in the middle somewhere where you can't even see it.
Really practical.
if you're keeping it n/a, then your stock fuel, speedo, temp and tacho are going to be fine (I'm assuming you're not going to do any uber mods)
only thing you might consider is oil & fuel pressure. depends how you run your car as to whether you should even bother. for a car that's not highly modified, there's no real need (oil pressure and fuel pressure are only really problems in uber-modified cars, unless you're running low on either)
[Updated on: Tue, 20 May 2003 10:59]
RobST162
Re: Gauges - Should I bother? Tue, 20 May 2003 11:41 Go to previous messageGo to next message
dumb question alert.. please be patient...
my 3sge has a very low pressure reading on the gauge. so I had it tested, and the pressure is fine in the engine, therefore, my sender isn't working properly.
Is this a big deal? Should I get a new sender off Toyota? You mentioned that is is impt to have the guage, so I am thinking, is it therefore important to have one that is working well Smile
Re: Gauges - Should I bother? Tue, 20 May 2003 11:47 Go to previous messageGo to next message
it's "important", in that if your engine is ever likely to get low pressure, it's a really good idea to know about it!
but on most engines, this generally happen at low oil levels.
kingmick
Banned by his request
moved to tamworth
Re: Gauges - Should I bother? Thu, 22 May 2003 11:34 Go to previous messageGo to next message
speedo,tacho,water temp and oil pressure. then add oil temp{the best engine gauge to have} and fuel pressure and last, volts.
mick
SW20R
Re: Gauges - Should I bother? Thu, 22 May 2003 12:01 Go to previous messageGo to next message
vacuum gauge, to check on your breathing Smiley =
RobST162
Re: Gauges - Should I bother? Thu, 22 May 2003 23:20 Go to previous messageGo to next message
So, my pressure sender is stuffing up. Shall I risk a second hand one? (though mostly they get sold with the engines) or go straight and get a new one from Toyota?
Re: Gauges - Should I bother? Thu, 22 May 2003 23:28 Go to previous messageGo to next message
Well a lot of us have got about half a dozen of the things lying round anyway, just get friendly with someone who does! Evil or Very Mad
toycelica77
bris
Re: Gauges - Should I bother? Fri, 23 May 2003 02:38 Go to previous messageGo to next message
Flem wrote on Tue, 20 May 2003 20:25
i rarely drive of my speedo... you can judge your speed by your gear and what rpm you are doing...
although, i can pretty much feel all the speeds, i.e 60-70 and 100
Re: Gauges - Should I bother? Fri, 23 May 2003 02:49 Go to previous message
mrshin... what's happening in your avatarpic? Smile
tell the story!
Previous Topic:Toyota Corona Conversion
Next Topic:AE82 and KE70 Vehicle Dimensions / manuals
Current Time: Thu Oct 22 08:59:22 UTC 2026
Total time taken to generate the page: 0.031699895858765 seconds
