Toymods » Tech & Conversions » iggte clutch upgrade question
adrianharper1
launceston
iggte clutch upgrade question Mon, 19 May 2003 09:50 Go to next message
hi
i have an ra40 celica with a 1ggte engine.
i am not running any of the factory computer or loom.
i built the car about 9 years ago and just recently did some performance upgrades (separate turbo intakes 2.5" each, 3 inch exaust,gen3 turbos, etc)the car runs a wolf 3d ecu water to air intercooler and all of the usual performance upgrades, i originally used a hilux clutch, but now the extra hp has totally overpowered the clutch. it now spins the clutch in most gears. does anyone know of a clutch upgrade that i may not know about. bearing in mind that the flyweel and current clutch are generation 1 as gen 2 and 3 were not around when i did the conversion. also where is the best place to buy gaskets bearings etc.
any help greatly appreciated
Re: iggte clutch upgrade question Mon, 19 May 2003 11:04 Go to previous messageGo to next message
Sounds like you need a button clutch or, if the budget permits, a twin-plate. Go and see a clutch specialist!
dcving
newcastle nsw
Re: iggte clutch upgrade question Mon, 19 May 2003 22:15 Go to previous messageGo to next message
sorry a little off topic but,
id be interested in knowing some power figues & or times you are running?
also what gen engine is it as you stated that you put gen3 turbos on it?
are you running dizzy or coil pack?
sorry bout the questions but im running a similar set up & just curious bout how much power your making.
Re: iggte clutch upgrade question Mon, 19 May 2003 23:27 Go to previous messageGo to next message
What kind of power are you making? A 1G with CT12s should be able to survive on a full face single plate clutch, provided it's up to scratch. Have a talk to Direct Clutch, he should be able to make up a pressure plate with a decent amount of force to hold things together.
adrianharper1
launceston
Re: iggte clutch upgrade question Tue, 20 May 2003 01:58 Go to previous messageGo to next message
we are running commodore coil packs running off the wolf
i am only using dizzy for the crank angle sensor, located in the bottom of the housing the rest of the dizzy was cut off to allow more room for the turbo intakes.
the car produces about 250-260 kw (you dont need to upgrade from the gen 3 turbos thay can produce 18 psi all day if you upgrade the massivly restrictive turbo intakes and give each turbo a descent size inlet with its own air filter, so the turbo's arnt fighting with each other for air, which they are standard!. it is also important to put as big as possible exaust pipe (i used 4") for about the first 80cm then into 3" for the rest this allows the turbo's to spin more freely with less back pressure.
bigger turbo's will only give you more lag.
the gine produces good power up to about 7500 revs, it will rev harder but there is no real point. i am running a gen1 engine with gen three stuff so its basically a gen 3 now.
adrianharper1
launceston
Re: iggte clutch upgrade question Tue, 20 May 2003 02:04 Go to previous messageGo to next message
not sure on times etc
the car is our demo car for work i own a car audio store.
it has an mtx rfl 15" sub which weighs a ton by it self then add the 40mm graftwood that makes the 150 litre englosure and amps etc the car,s not so quick these days. but it will still do a high 12 second pass.
adrianharper1
launceston
Re: iggte clutch upgrade question Tue, 20 May 2003 02:20 Go to previous messageGo to next message
just for your interest the car runs commodore discs that fit strait on the ra40 hubs no mods, and volve calipers,
i am running the standard 5 speed box that came with the engine, mod tail shaft, custom made 4.1 lsd in cut down vl commodore housing and vl turbo rear calipers, 17" crome rims commodore stud pattern as front discs give that stud pattern and amazingly these discs also give the exactly right off set for commodore rims on an ra40 celica, i found out this totaly by accident, its the same on most celicas i think!!!!
punkdefender
Dandenong/VIC
Re: iggte clutch upgrade question Tue, 20 May 2003 10:42 Go to previous messageGo to next message
have any pics of the engine bay?
dcving
newcastle nsw
Re: iggte clutch upgrade question Wed, 21 May 2003 21:11 Go to previous messageGo to next message
u, using standard turbo manifolds?
what, model holden coil packs? im using ford
250kw, at the flywheel id imagine? wats that about 200 at the rear?
as for clutch, im using a solid centre 4 puck ceramic button, works quite well Smile
and i would also like too see some pics please
[Updated on: Wed, 21 May 2003 21:13]
adrianharper1
launceston
Re: iggte clutch upgrade question Thu, 22 May 2003 07:43 Go to previous messageGo to next message
using vs coil packs
standard turbo manifold so far
been quite a few years since i dyno'd it
it ran about 257 at the fly wheel but engine tuner predicts around 300 something now, engine is out at the moment because clutch couldnt handle it,so we havn't dyno'd it again i will let you know actual figures soon.
where did you get your clutch. My flyweel is the smallest one. my gen 3 came with the larger flyweel that wont fit my bell housing etc, is yours the gen 1,2or3.do you know if the gen two has the same flyweel as the gen 1 or gen 2 or different again
gold28
Madrid - Spain
Re: iggte clutch upgrade question Fri, 23 May 2003 03:41 Go to previous messageGo to next message
Have you thought about just getting a stronger pressure plate.
I am interested to see what your manifold looks like, sounds like a good option for a power increase.
Dylo
Re: iggte clutch upgrade question Fri, 23 May 2003 06:22 Go to previous message
Have u tried a 1JZ GTE pressure plate? All you have to do is to drill out the locating pin holes a little bit and its straight on, i imagine this applies more pressure than the 1GGTE one, I run it in mine with a heavy duty double sprung hilux clutch-plate, havent really tried it yet as my car isnt totally finished. but i assume it will grab nicely!
Previous Topic:20v quads / turbo / manifolding / ke10
Next Topic:2tg EFI problems, car idles but wont rev....
Current Time: Sat Oct 24 06:03:40 UTC 2026
Total time taken to generate the page: 0.0051491260528564 seconds
