Toymods » Tech & Conversions » Axle Tramp
Axle Tramp Mon, 19 May 2003 10:13 Go to next message
Anyone got some suggestions for lessening axle tramp? On my turbo AE86 it can get quite severe when launched hard. It can be lessened by carrying Yogorilla in the back seat, but he tends to get an upset stomach with my driving Shocked Anyway, the shocks are fine (koni yellows), everythings done up, all the bushes are good, etc. Any suggestions? (Apart from installing drag shocks - I DO actually like to go around corners!)
Jonoze
Re: Axle Tramp Tue, 20 May 2003 04:56 Go to previous messageGo to next message
Hey mrshin,
Unfortunately i cant offer you a solution, but I've got the same problem. And funnily enough i'm running the same diff and gearbox. Except i have a two piece tail shaft.
Its really frustrating when your trying to get a decent launch. As soon as you get a bit of wheelspin the diff trys to remove itself from the car rather violently. Wet weather only compounds the problem for me.
One thing i have been told to try is to increase the pinion angle of the diff. I.e. rotate the nose of the diff down. This can be done by getting adjustable upper arms and shortening them. Whiteline sell these for about $230.
I havent got a set of these yet as my moneys going elsewhere. I have slotted the holes on the lower arm mounts on the diff. This gave me a bit more anlge but the tramp is still there. I was going to slot the upper arm holes when i get a chance and see if that helps.
The only other thing i need to do is to replace the bushes.
The only thing i can really put it down to is that the diff shop has stuffed the alignment of the brackets when they swapped them from the original diff.
If you or anyone else gets any ideas please let me know.
Re: Axle Tramp Tue, 20 May 2003 05:28 Go to previous messageGo to next message
Yeah, anything else you find out would be nice Very Happy I'll put it to some of my old school drag racing buddies when next I see them, see if they can come with a a solution more appealing than ladder bars Very Happy
Re: Axle Tramp Tue, 20 May 2003 05:30 Go to previous messageGo to next message
Oh yeah, and the annoying thing is that it's been getting worse over the last few weeks - I've taken to diff out (I was replacing the LSD) and checked all the bushes, bolts, bodywork, etc., and can't see anything busted. Annoying thing is that the diff has rubbed a hole in my exhaust - a 3" pipe has minimal clearance at any time, and such un-gentleman like movement of the diff sure doesn't do it any favours...
Jonoze
Re: Axle Tramp Tue, 20 May 2003 05:33 Go to previous messageGo to next message
Yeah mine rubs on my 2.5 inch exhaust. I also think the tramp was partly responsible for braking one of my shocks.
What lsd have you put in yours? I've got the standard skyline setup and its pretty much wearing out after only about 6 months.
TA22-3SGTE
MACKAY
Re: Axle Tramp Tue, 20 May 2003 10:35 Go to previous messageGo to next message
What tyre pressure are you running , Try dropping the pressure a bit .
Trevor
Re: Axle Tramp Tue, 20 May 2003 10:58 Go to previous messageGo to next message
I'm using a KAAZ LSD in the skyline case - working great. Bloody pricey though! If you got 6 months out of the cone type one, you must be treading lightly Very Happy Mine died after about 6 days...
I've already tried playing with pressures, doesn't do much Mad
TA22-3SGTE
MACKAY
Re: Axle Tramp Tue, 20 May 2003 12:18 Go to previous messageGo to next message
I've had a lot of this trouble in the past in various cars and the best thing that I found that works is replacing the standard bushes with urethane bushes 99% of the time this will work straight up even with crappy springs and shocks.
Re: Axle Tramp Tue, 20 May 2003 12:21 Go to previous messageGo to next message
Bushes are already all urethane, shocks are Koni and still working fine
TA22-3SGTE
MACKAY
Re: Axle Tramp Tue, 20 May 2003 12:29 Go to previous messageGo to next message
Sorry mate I have got no idea then. Confused
Re: Axle Tramp Tue, 20 May 2003 12:31 Go to previous messageGo to next message
Get a new car, that will fix it Very Happy
Re: Axle Tramp Tue, 20 May 2003 12:42 Go to previous messageGo to next message
Can't I kill this one first??? Evil or Very Mad
Yes, yes, one day...
TOY77
Re: Axle Tramp Tue, 20 May 2003 21:25 Go to previous messageGo to next message
g'day...
i have a celica with a 1ggte and a volvo diff...
had heaps of probs with tails shaft hitting floor and other fucking round....
a mate with a workshop (JT performance in newcastle)made me up a set off adjustable upper control rods and now she is sweet as!!
At dubbo i launched with everything i had and no issues at all.
I think he was looking at doing them for around $250 with a complete urathane bush kit (worth bout $125).
if you are interested let me know.
Stew
adrianharper1
launceston
Re: Axle Tramp Wed, 21 May 2003 09:44 Go to previous messageGo to next message
urathane bushes can some times cause the rear end to be two stiff causing axle tramp i had the same problem with my ra40 with 1ggte and i have been tolt to put standard bushes back in the top arms only to allow them to move a bit. i havent tried it yet but they seemed very confident that, that was the problem, its worth a try and its cheep
Bugman
Re: Axle Tramp Wed, 21 May 2003 10:03 Go to previous messageGo to next message
what about firmness of suspension(springs and shocks) I put new springs and shocks in the rear of my 28 and it solved my axle tramping problems.
Re: Axle Tramp Wed, 21 May 2003 13:04 Go to previous messageGo to next message
I've already got fairly stiff springs, shocks and bushes, and these may be making the issue worse... but still
TOY77, if you can put me onto some decent adjustable arms, by all means do so Very Happy Also, you dont happen to drive a red RA28, do you?
Bugman
yeah my new stuff is softer.
Youngy
Eskilstuna, Sweden
Re: Axle Tramp Wed, 21 May 2003 22:45 Go to previous messageGo to next message
Argggghhh mrshin!
I have the solution and it is not going softer on your set-up. I bet you have lowered your car when you put in the new suspension components this of course has two affects that are causing tramp
1. The diff angle or pinion angle (depends who you talk to) as has been highlighted already is changed or has been altered
2. The angles of your four trailing arms to the diff/axles has also been changed.
Whiteline do make some very good adjustable upper arms for the sprinter that can help to resolve point 1. You will also need an adjustable panhard rod to accompany this set-up to help keep the diff centered and at the required pinion angle.
For the more hardcore to resolve point 2 you will need to weld up (or bolt on some extensions, but they seem weak to me, like the battleversion ones) new mounting points for your lower control arms to return them to the factory angle at the lowered height.
That should do it! Send me a PM with your email details and I can back this up with some pics.
[Updated on: Wed, 21 May 2003 22:47]
Re: Axle Tramp Wed, 21 May 2003 23:01 Go to previous messageGo to next message
I've already got the adjustable panhard bar - the thing that annoys me is that this problem has only recently surfaced, a couple of weeks before I took my diff out. As I said, I checked out everything while it was out, found nothing up, but I will definately look into the adjustable upper arms.
Youngy
Eskilstuna, Sweden
Re: Axle Tramp Thu, 22 May 2003 01:21 Go to previous messageGo to next message
Interesting, This is a long shot but here goes:
If your springs and shocks are not that old, it couldbe that they have started to drop slightly as they bed in and this has been enough to change the angles etc to induce tramp. Long shot though.
Cheers.
Three and half linking sounds like bollox......call me skeptical
[Updated on: Mon, 28 July 2003 11:43]
Fat_KE70
Shepparton
Re: Axle Tramp Thu, 22 May 2003 12:35 Go to previous messageGo to next message
One solution i have heard of is to get a shortish shock absorber and weld a mount somewhere to the snout of the diff at one side and the other mount through the floor. works (obviously) by absorbing the forces of the torque effect(when the diff snout goes upwards under acellaration)and where tramping it is going up and down really quick... dont get too stiff a shock though cos it will then try to flex elsewhere(control arms etc),
drastic i know but you know what they say about desperate times.
allencr
tallahassee FL usOFa
Re: Axle Tramp Thu, 22 May 2003 17:04 Go to previous messageGo to next message
soft motor & trans mounts also contribute to this. the entire drivetrain is twisting up and then releasing this energy, not just the rear suspension.
i think the pinion angle is only important for u-joint wear, but it does add to this problem by "pulsing" the power flow and possibly adding to the problem.
TOY77
Re: Axle Tramp Thu, 22 May 2003 21:25 Go to previous messageGo to next message
g'day.
well they did work on mine....
the price above is what he said he can do...
i can get his number for you if you like?
My ra28 is wrx rally blue...
Stew
Re: Axle Tramp Thu, 22 May 2003 23:32 Go to previous messageGo to next message
Yeah his number would be nice Very Happy
Good guess that you had an RA28 ey? although I thought you were someone else!
Jonoze
Re: Axle Tramp Thu, 22 May 2003 23:35 Go to previous messageGo to next message
I know whiteline make adjustable upper arms. Dont know what they are like tho. They were about $250 or so. I think they came with bushes. I will buy a set eventually.
purpleminiep
Mentone
Re: Axle Tramp Fri, 23 May 2003 00:02 Go to previous messageGo to next message
Like Youngy said you have changed the angle of the control arms which changes the roll centre and the twist centre. If you lower the rear of the bottom arms to the angle of the original height it will help alot. It is similar to lowering a car and not using rca on the front. You are messing up all the factory angles. If your Koni's are adjustable try running softer settings.
Brad
Bill Sherwood
Brisbane / Gold Coast
Re: Axle Tramp Fri, 23 May 2003 00:28 Go to previous message
Rose joint the lower arms and the upper-right. Leave the rubber bushes in the upper-left.
That's called 'three and a half linking' the rear end, and the car will not axle tramp after that.
Previous Topic:91 Celica power window wires
Next Topic:What splits should i get for my car?
Current Time: Sat Oct 17 18:45:36 UTC 2026
Total time taken to generate the page: 0.010572195053101 seconds
