Toymods » Tech & Conversions » crank angle sensor ae86 20v
purpleminiep
Mentone
crank angle sensor ae86 20v Mon, 24 June 2002 05:52 Go to next message
Like the title says what do people run as crank angle sensors when they have a 20v in their sprinter. Does the dizzy fit without the cap and rotor. I am going to rum aftermarket computer. I thought mabye a 4agze sensor may fit somehow.
Brad
Mr 20Valve
Re: crank angle sensor ae86 20v Tue, 25 June 2002 07:02 Go to previous messageGo to next message
Brad,
im running the stock 20V dizzy (minus rotor & cap) as a crank angle sensor, feeding signal to a Microtech MTX-8, running coil packs from a 4AGZE.
the dizzy is capped off with a blanking plate similar to the ones found on the 4AGZE as well....
so does it fit??? in a word, yes. Smile
purpleminiep
Mentone
Re: crank angle sensor ae86 20v Tue, 25 June 2002 08:11 Go to previous messageGo to next message
Thanks That helps heaps. Just another question are you running two or foru coils.
Brad
purpleminiep
Mentone
Re: crank angle sensor ae86 20v Wed, 26 June 2002 14:07 Go to previous messageGo to next message
Do you have any pictures of how you ran the coolant pipes. Where do you have your thermostat? How did you modift the take off on the back of the head/block
Brad
Re: crank angle sensor ae86 20v Fri, 28 June 2002 07:41 Go to previous message
This is something I wanted to know too - does a 16v 4ag dizzy fit in a 20v head? Cos I've got a custom trigger in my 16v head, and was wondering how cheap/easy I could screw a 20 in place of it, and I'd like to keep my igniton trigger.
Previous Topic:Qs, about engineers ceritificate
Next Topic:2TGEU Timing & Injectors
Current Time: Thu Nov 19 15:31:11 UTC 2026
Total time taken to generate the page: 0.03299880027771 seconds
