| Author | Topic |
How to cut aluminium?
Tue, 20 May 2003 06:14
I have 10mm aluminium plate and I need to cut out a gasket
shape. How do I cut it? What is best to use to cut it?
Re: How to cut aluminium?
Tue, 20 May 2003 06:21
Jigsaw?... with a metal blade..
but I dont know if blades are available for such thick metal.
Tue, 20 May 2003 06:28
Tried that earlier but doesnt seem to cut it that well. Im looking for other options.
Tue, 20 May 2003 08:04
drills, holesaws etc. failing that, take oit to a laser/watercutting place or something.
Tue, 20 May 2003 10:23
Umm a little bit off topic but does anyone know how to weld titanium?
Tue, 20 May 2003 10:29
A good jigsaw with the right blade will cut it but you must keep it well lubricated while cutting , a light oil will do .
Trevor
Wed, 21 May 2003 01:49
| Snyper wrote on Mon, 12 May 2003 18:51 | I have seen this car in the flesh, I almost bought his iold set-up with the supercharged 2tg. it is a sweet paint job, and it is also 7 years old, has been sitt
Wed, 21 May 2003 04:15
I've cut 5mm with a jigsaw and I'll agree that it does suck. A sabre-saw is a much better bet, but, not cheap...
Wed, 21 May 2003 06:26
Ive got 6mm sheet alu here that i cut bits from quite often with a normal jigsaw and steel blade.
If i go slow, i find i have no problems... just takes time.
Wed, 21 May 2003 06:29
We used chippies circular saw to cut the flat edges on 8mm. The rest was done with a jigsaw with metal blades. Its loud, creates heaps of al dust and we snapped a heap of them, but its the only way we had of doing it.
Finished it off with a rasp, then a file. Takes time, looks trik!
Banned by his request
Thu, 22 May 2003 11:04
use jigsaw,bandsaw or mill for complex shapes. titanium is welded in a gas shield{contained gas tent}. very few people do it or i should say have much experiance with it.
mick
Fri, 23 May 2003 03:46
A proper metal band saw is much better than a jig saw. Alternatively find someone with a mill and do it properly.
I think titanium needs to be tig welded.
Fri, 23 May 2003 05:51
Cant use a metal jigsaw blade on alloy it will just gall
Use a woodcutting blade in the jigsaw
Same as cutting sheet use a hand saw for wood it will cut it like butter and wont damage the saw as alloy is softer than wood
when drilling holes with a hole saw drill some holes around the circle the saw will cut for the shavings to disappear down
Fri, 23 May 2003 08:26
Thats interesting about the wood blades. I have some mean looking wood blades so I will give one a try and see how we go.
Fri, 23 May 2003 12:20
oxy
Toymods member I supported Toymods
Fri, 23 May 2003 14:36
I cut out my Scorpion's (last car) aluminium from 1.6mm checkerplate with a wood blade in a jigsaw. The project was to make a false-floor in the boot. Pics available on request. Take it slow and it does the job just fine. A LOT of aluminium splinters though.
My latest project (a 3mm thick checkerplated bashplate) I also did with the same tools, except it just took a bit more time to do. I know what 10mm aluminium is like, so I'd suggest using maybe a high-tensile hacksaw blade? Or like others have suggested - get it done at a laser-cutting place.
Sat, 24 May 2003 07:35
OXY WILL NOT CUT ALUMINIUM!!!!
take it too any light fab shop and they can cut it
they will use a plasma cutter
Sat, 24 May 2003 12:37
I've cut plenty of Aluminium with a jigsaw. I use metal blades, and keep spraying the blade with CRC or WD40. If you stop spraying it, it will clog the blade and break it. When you give the blade a spray, you can feel the saw take off. Like a hot knife through butter.
| Current Time:
Wed Oct 28 05:24:58 UTC 2026 |
Total time taken to generate the page: 0.012883901596069 seconds |
