Toymods » Tech & Conversions » MX65/MS65 hubs?? Help
MX65/MS65 hubs?? Help Wed, 21 May 2003 08:52 Go to next message
I have been searching around wreckers for some MS65 hubs and finally found a place that said they had some.
I picked them up today and they have MX65 written on them Confused
I checked on the DBA database and cant even see an MX65 listed, So I was thinking they could actually be MS65 hubs. I measured the rotors that were still attached and they roughly measure 275 x 16mm. This is all good but the DBA site has the MS65 rotors listed as 266 x 12.7mm.
So i'm totally f#*ckin lost Sad Anyone have any idea what I may have?
Re: MX65/MS65 hubs?? Help Wed, 21 May 2003 11:06 Go to previous messageGo to next message
You probably actually have some rarish MS55 hubs. The MS55 actually came out with 2 types of disc brakes - PBR set and a Sumitomo set. I believe the PBR set actually ran 274 mm rotors.
Ultimately what is important here are the hubs - they should be identical.
I suggest you whip off the rotor and measure the hubs up. Compare these with the measurements on Ed's site. The bearings should be identical.
If they are not the same, I could probably get you a set of hubs for $50-60. I'd have to check the car is still there though.
Re: MX65/MS65 hubs?? Help Wed, 21 May 2003 11:09 Go to previous messageGo to next message
Thanks mate! I'll measure the hubs on the weekend. I'm thinking i'm going to have fun trying to get the rotors off Confused
So what does the MS55 look like?
Re: MX65/MS65 hubs?? Help Wed, 21 May 2003 11:12 Go to previous messageGo to next message
Series 1 MS55:
http://members.surfeu.fi/petteri.s/crown/kuvat/crown50.gif
Series 2 MS55:
http://koti.mbnet.fi/toycar/jasenet/crown/crown010.jpg
Soak the rotor retaining bolts in some WD40 tonight in readiness for the weekend. Usually they are pretty easy to whip off.
Also the PBR rotors were a purely Australian thing. Everywhere else got Sumitomo twin spots.
[Updated on: Wed, 21 May 2003 11:16]
Re: MX65/MS65 hubs?? Help Wed, 21 May 2003 11:15 Go to previous messageGo to next message
Thanks.
The model should be stamped in the engine bay somewhere shouldnt it? I might ring the wreckers I got them from and see if they can check for me!
Re: MX65/MS65 hubs?? Help Wed, 21 May 2003 11:21 Go to previous messageGo to next message
Cool1 wrote on Wed, 21 May 2003 21:15
Depends. Pre 68 Crowns definitely didn't and I can't be sure about the MS55. It was stamped elsewhere not ever checked by the RTA types (nor am I prepared to reveal it here) - this is a common way of registering multiple MS45s with one rego payment.
Re: MX65/MS65 hubs?? Help Wed, 21 May 2003 11:25 Go to previous messageGo to next message
LOL Laughing
Thanks. I'll ring and ask anyway.
Re: MX65/MS65 hubs?? Help Wed, 21 May 2003 11:29 Go to previous messageGo to next message
Sorry to be a little coy about that, but it's nice to have a couple of cars all registered at cut price. Just swap the plates, and if you get pulled over, you swapped the motor on the weekend.
Re: MX65/MS65 hubs?? Help Wed, 21 May 2003 11:50 Go to previous messageGo to next message
Thats ok mate I full understand! I dont really care what these come off has long as they are the same as the MS65!
Re: MX65/MS65 hubs?? Help Thu, 22 May 2003 08:58 Go to previous messageGo to next message
Does the outter casing of the bearing come out of the hub or does the hub make part of the bearing Confused Hope that makes sense Rolling Eyes
ed_ma61
Lost in the K hole
Re: MX65/MS65 hubs?? Help Thu, 22 May 2003 14:18 Go to previous messageGo to next message
the outer casing comes out. you need to punch it out from the other side of the hub with a drift and a hammer.
shane, just measure the bore dia that the bearings are pressed into, and let me know... ill tell you if theyre going to work or not..
ed
Re: MX65/MS65 hubs?? Help Thu, 22 May 2003 20:59 Go to previous messageGo to next message
Thanks mate.
Re: MX65/MS65 hubs?? Help Fri, 23 May 2003 07:49 Go to previous messageGo to next message
Ok the large bearing outer casing measures 59.13mm and has LM67010 written on it, the small outer casing measures 45.24mm and has LM11910 written on it.
Let me tell you I nearly tore myself a new arsehole removing them casings Confused
Re: MX65/MS65 hubs?? Help Fri, 23 May 2003 09:58 Go to previous messageGo to next message
http://www.buyknows.com/htm/tech_refe_03.htm
What are your spindle diameters?
Outer should be 19.05mm, and inner should be 31.75mm.
Re: MX65/MS65 hubs?? Help Fri, 23 May 2003 10:05 Go to previous messageGo to next message
I have no idea at the moment! I hope to use some RA40 struts
Confused
Re: MX65/MS65 hubs?? Help Sat, 24 May 2003 01:34 Go to previous messageGo to next message
celica ra40, ra60, sa63, ra65
cressida mx32, mx36, mx62, mx73
crown ms65
corona rt81, rt104, xt130, rt133, st141, rt142
avante st141, rt142
spacia yr22
lite ace km20, cm20, cm35, ym21, ym30, ym35
supra ma61
tarago yr20, yr21, yr22 2wd, cr21
All the above vehicles share the same front hub bearing. You're in luck.
Re: MX65/MS65 hubs?? Help Sat, 24 May 2003 11:24 Go to previous messageGo to next message
Well I went and got ripped off on some RA40 struts today and also picked up some bearings so i'll see how I go tomorrow Very Happy
ed_ma61
Lost in the K hole
Re: MX65/MS65 hubs?? Help Sat, 24 May 2003 14:36 Go to previous message
shane, those bearing part numbers and dimensions are correct... congrats, you currently own a pair of 5 stud front hubs for your humble ra40 struts Very Happy
ed
Previous Topic:3T-GTE: Which viscosity of engine oil?
Next Topic:Finally decided what to put into EH..
Current Time: Thu Oct 29 02:48:16 UTC 2026
Total time taken to generate the page: 0.027184009552002 seconds
