Toymods » Tech & Conversions » 91 Celica power window wires
Team_Weall
Perth WA
91 Celica power window wires Thu, 22 May 2003 14:19 Go to next message
hey all my alarms got a feature to wind up my windows via the remote. wats the go with the switches. first is it positive switched? and second what colour wire is it that runs to the wind up switches for both windows (the switches mounted in the drivers arm rest)
im assuming this is how it works switchs is pressed up closing the cuircut allowing 12 volts + to run through which causes the window to wind up.
BansheeBuzz
Gold Coast
Re: 91 Celica power window wires Thu, 22 May 2003 21:05 Go to previous messageGo to next message
both wire to the window motor are earthed until the elec window switch is opperated.
at this point on of them will be switched to a positive to make the window operate.
You best read through your install guide carefully otherwise you will blow fuses!
As fow which wire? you will need to get into the back of the main window switches and work it out for yourself.
If your switches are on your door then you will have to run wires into there.
Team_Weall
Perth WA
Re: 91 Celica power window wires Fri, 23 May 2003 00:57 Go to previous message
thanks banshee. thats pretty muc heverything i was asking. looks like ill ust have to take the door apart to find the wire. i was hopin gthe switch wires would have run out into the pickpanel where all those relays and stuff are
Previous Topic:AE82 4agze conversion (transmission)
Next Topic:Axle Tramp
Current Time: Thu Oct 15 12:38:34 UTC 2026
Total time taken to generate the page: 0.0042409896850586 seconds
