Toymods » Tech & Conversions » 20v quads / turbo / manifolding / ke10
pro_ke
adelaide
20v quads / turbo / manifolding / ke10 Fri, 23 May 2003 02:39 Go to next message
does anyone know if anyone has put 20v quad throttle bodies on a K series motor? (ie 4k etc) if so, is there an off the shelf manifold available?
I am desinging 4k turbo manifolding at the moment and i am not really sure of which route to take on the inlet side :
- single dcoe weber manifold + dcoe throttle body
- 20v quad throttle bodies on a custom manifold?
- 4k factory injection manifold
- ida throttle body on custom manifold?
i am leaning toward the 20v or DCOE setups however i do not think there will be enough room in a ke10 for weber manifold+throttle body+plenum chamber between the motor and strut tower...
any ideas anyone?
Ben Wilson
Re: 20v quads / turbo / manifolding / ke10 Fri, 23 May 2003 03:13 Go to previous messageGo to next message
For a turbo setup I wouldn't go for quads personally. They are hard enough to balance as it is, with a sealed plenum on the end of them, they would be a nightmare..
pro_ke
adelaide
Re: 20v quads / turbo / manifolding / ke10 Fri, 23 May 2003 04:56 Go to previous messageGo to next message
very good point. i was thinking in terms of actual size (ie length) these are quite short but yeah i can see how it would be painful.
depending on the length of available weber manifolds i think the DCOE throttle body will only just clear the strut tower... fine for a NA setup but with a plenum chamber on the end of it i thin kit would struggle to fit at all.
Grega
melbourne.victoria.austra...
Re: 20v quads / turbo / manifolding / ke10 Fri, 23 May 2003 06:52 Go to previous messageGo to next message
4KE inlet manifold if you can get one would be the way to go!
pro_ke
adelaide
Re: 20v quads / turbo / manifolding / ke10 Fri, 23 May 2003 07:59 Go to previous message
Grega wrote on Fri, 23 May 2003 16:52
the inlet is not really where i want it to be for this project, however if anyone has one for sale i will still buy it
ab
Previous Topic:Bodykit for 1985 ST Celica Coupe
Next Topic:iggte clutch upgrade question
Current Time: Sat Oct 24 16:21:02 UTC 2026
Total time taken to generate the page: 0.014178991317749 seconds
