Classifieds » Miscellaneous » 2JZGTE Injectors
Grant
Newcastle, NSW, Australia
2JZGTE Injectors Fri, 23 May 2003 23:02 Go to next message
Set of Jap Spec 440cc 2JZGTE injectors. $450.
blackRA28
adelaide
Re: 2JZGTE Injectors Sat, 24 May 2003 02:37 Go to previous messageGo to next message
out of interest, what impedance are these injectors?
Grant
Re: 2JZGTE Injectors Sun, 25 May 2003 21:56 Go to previous messageGo to next message
13 ohms from memory. They will interchange with 1J injectors.
JAZE
cronulla
Re: 2JZGTE Injectors Mon, 26 May 2003 13:18 Go to previous messageGo to next message
if they will run with my factory 1J computer? then consider them sold.
Grant
Re: 2JZGTE Injectors Mon, 26 May 2003 22:18 Go to previous messageGo to next message
Hi Jaze,
Yes, they will run with the 1J ECU but I wouldn't suggest using them unless you really need the extra fuel. There is someone else intersted in them so if you do want them email me ASAP.
Grant
[Updated on: Mon, 26 May 2003 22:18]
Bentt
Re: 2JZGTE Injectors Thu, 29 May 2003 05:26 Go to previous messageGo to next message
They will drop straight in to a 1jz... I have them fitted to my 1jz Smile It will run.. but will be rich for obvious reasons.. I'm not sure yet whether the ecu will self-learn enough to run them nicely... will know in a week or two Smile
Ben
Grant
Re: 2JZGTE Injectors Thu, 29 May 2003 05:32 Go to previous messageGo to next message
The ecu will not 'self-learn'. At cruise or idle the ecu's closed loop will cut back injection duty cycle but during throttle the duty cycle will remain as it did when the standard injectors were fitted resulting in a rich mixture. In other words, unless you have need for extra fuel (bigger turbo for instance) don't use bigger injectors with a standard ecu.
Bentt
Re: 2JZGTE Injectors Thu, 29 May 2003 05:38 Go to previous messageGo to next message
It will self learn for idle etc.. under I think it's 40% TPS from memory... but yeah at more then that to WOT it will revert back to the open fuel map.. and no doubt will be too rich... An easy fix would be a SAFC... though not the best approach...
There is no need for larger injectors with the stock turbo's anyways... They will support around 250kw atw's... about where everything stock runs out.. fuel pump, injectors etc...
KOFFEE-BLACK
Are these the same as the 2jzge injectors?
Grant
Re: 2JZGTE Injectors Thu, 29 May 2003 05:43 Go to previous messageGo to next message
No. 2JZGE injectors are standard top-feed. 1J and 2J turbo ones are side feed.
Bennt, closed loop is for idle, cruise and light throttle opening only but I won't argue about about percentages. The rest of your response is curious - have you modified the 1J or did you just stick the 2J injectors in to see what would happen?
Bentt
Re: 2JZGTE Injectors Thu, 29 May 2003 05:49 Go to previous messageGo to next message
Mod'd... Custom manifold T04 turbo 60-1 compressor wheel in a 0.7 A/R 4 inch inlet cover... P-trim exhaust wheel 0.82 A/R split pulse T3 style flange... 32mm External Gate... 3.5inch dump.. back to twin 3's... 2jz injectors.. Malpassi Reg, and UNIchip... etc etc etc... Will be hopefully done ready for tuning next week or the week after... Smile
Grant
Re: 2JZGTE Injectors Thu, 29 May 2003 05:53 Go to previous message
Why did you opt for the unichip and not full aftermarket?
Previous Topic:FS Sony headunit MD/CD remote
Next Topic:18rgu and box for sale - Brisbane
Current Time: Thu Nov 19 17:58:09 UTC 2026
Total time taken to generate the page: 0.0058650970458984 seconds
