Toymods » Tech & Conversions » ma70 and jza70 dashes
ma70 and jza70 dashes Sat, 24 May 2003 10:57 Go to next message
just wondering if the ma7x turbo and jza70 instrument panels are interchangable. I know the chassis are the same, but the dashes would be slightly different (like, non-turbo ma70 wouldn't have the boost guage)
also concerned about whether all the guages will work
[Updated on: Sat, 24 May 2003 11:06]
Re: ma70 and jza70 dashes Sun, 25 May 2003 03:26 Go to previous messageGo to next message
They are interchangeable but there are some minor wiring differences from memory. Talk to Wastegate from these forums, he's done the swap recently.
wastegate
Gold Coast
Re: ma70 and jza70 dashes Mon, 26 May 2003 04:56 Go to previous messageGo to next message
Hi, tell you the truth I wouldn't know as I changed all the dash wiring as well in my car, but with the JZA70 Dash the gauges that are in the cluster are;
JZA70: [boost] [volt] [speedo] [tacho] [temp]
MA70: [boost] [oilprs] [speedo] [tacho] [temp]
The JZA70 runs a oil pressure warning light.
Here are the JZA70 Dash wiring diagrams http://jzgte.com/tech
The MA70 Wiring diagrams are here http://www.1jz-gte.us/documents/SubDocs4/25_D.pdf WARNING 36MB PDF Right Click save as.
Re: ma70 and jza70 dashes Mon, 26 May 2003 10:53 Go to previous messageGo to next message
thanks for that Smile
it's actually in relation to a sale I might be making
so everything will work except the volts/oil pressure light.. right?
Re: ma70 and jza70 dashes Mon, 26 May 2003 11:04 Go to previous messageGo to next message
are the plugs the same?
Re: ma70 and jza70 dashes Tue, 27 May 2003 07:32 Go to previous messageGo to next message
I just found out
the ma7x dash is the analogue one.
the jza70 is digital.
wastegate
Gold Coast
Re: ma70 and jza70 dashes Tue, 27 May 2003 07:43 Go to previous messageGo to next message
No you can get the digital dash in the MA70 as well. You can also get the analog dash in the JZA70 as well. I know as I have one.
Stenno
Re: ma70 and jza70 dashes Tue, 27 May 2003 07:50 Go to previous message
A volt gauge will go straight in place of the factory boost gauge - it's a straight swap over.
Previous Topic:how does the 4AGE Diagnosis work?
Next Topic:ke20 / ke25 front springs
Current Time: Fri Nov 20 09:00:28 UTC 2026
Total time taken to generate the page: 0.012321949005127 seconds
