Toymods » Tech & Conversions » Problem with my ae92 corolla
hotrolla
Problem with my ae92 corolla Sun, 25 May 2003 03:59 Go to next message
Okay I have a problem with my ae92 corolla
when ever I accelerate it makes a clicking sound from the
front left wheel and the back right wheel and it pisses me off alot Mad But it only happens in 1st, 2nd and some times into
3rd gear. Ive tighted every nut and bolt
Doe's anyone know want it is. Any advice would be great and very
helpful
Thanks Smile
Rolla Boy
Club Member
Sydney, NSW
Re: Problem with my ae92 corolla Sun, 25 May 2003 07:31 Go to previous messageGo to next message
Check your wheel bearings...
The front has a possibility of being a driveshaft problem but it sounds as though its the wheel bearings that are the problem...
hotrolla
Re: Problem with my ae92 corolla Sun, 25 May 2003 10:24 Go to previous messageGo to next message
Thanks man i will check them out
Smile
Rolla Boy
Club Member
Sydney, NSW
Re: Problem with my ae92 corolla Sun, 25 May 2003 10:49 Go to previous message
The front wheel bearings were a problem with the AE92 series Corollas... They regularly stuff up...
With the rear, just jack the rear of the car up and move the wheel around to check for movement...
With the front, jack the front up, remove the wheel, loosen the 30mm driveshaft nut maybe 5 turns put the wheel back on tight... Then check for movement... Thats the most efficent way to check the front bearings...
Also, check the front left driveshaft aswell while your already there... Check that the rubber boots aren't slpit and check for leaking grease also...
Previous Topic:Any panel beaters out there?
Next Topic:What are the benifits of a quad throttle body setup on a 16v 4age??
Current Time: Sun Oct 25 19:07:21 UTC 2026
Total time taken to generate the page: 0.070288181304932 seconds
