Toymods » Tech & Conversions » Just installed Walbro 550HP fuel pump
SUPRAGTE
North Sydney
Just installed Walbro 550HP fuel pump Sun, 25 May 2003 04:37 Go to next message
Just put my new 550HP fuel pump in. Cost $288 incl GST(Trade Price) from Petroject in North Parramatta.
The pump states on the outside its GSS294 but I couldn't find any specs on this particular pump anywhere on the net.
There are apparently two types of Walbro pumps in the 255L/Hour range. A high and low pressure, both for EFI but the higher pressure one delivers higher fuel volumes at high pressure which is what I need as i'll be cranking up the fuel pressure to squeeze more out of the injectors. Probably somewhere around 75psi.
Star Performance sell them for $300 and rate them at 500HP and they are identical pumps.
It doesn't take much to modify the standard intake bracket to fit. Just grind out the bottom holder of the standard bracket to fit the new pump which is alot smaller than the factory pump which was still providing enough fuel for 300rwhp.
Then cut and solder the wires, put a stainless hose clamp to ensure the pump stays on the bracket and fit the strainer/filter onto the bottom and your done.
The Walbro pump is noisy compared to the stock one when you turn the ignition on and whilst sitting at the lights idling. As soon as you push the pedal the noise dissapears. The pump is probably supplying too much fuel at idle and that's why she's noisy.
I also noticed an increase in fuel pressure(@ idle) to 43psi over 38psi previous which i'll have to dial back down to 38psi with the Malpassi regulator.
This fact proves the new pump is supplying more fuel already as the increase in pressure without any other mods shows.
Apart from the slight increase in noise i'm reasonably happy, i'll see how she flows on the dyno. Smile
EMP-2TG
Carlingford, Sydney
Re: Just installed Walbro 550HP fuel pump Sun, 25 May 2003 04:55 Go to previous messageGo to next message
nice man
it will be good to see what power you can make now
SupraPete
Re: Just installed Walbro 550HP fuel pump Sun, 25 May 2003 08:38 Go to previous messageGo to next message
Great!
My fuel pump gets really noisy. My little bro said it needs some noise suppressors. Do you know what these are? Did you put any in?
Re: Just installed Walbro 550HP fuel pump Sun, 25 May 2003 08:42 Go to previous messageGo to next message
Noise suppressors only remove electrical noise not mechanical noise.
SupraPete
Re: Just installed Walbro 550HP fuel pump Sun, 25 May 2003 11:09 Go to previous messageGo to next message
Not trying to hyjack the thread, but can you tell me more about the noise suppressors? what they look like, where they go, how many you need etc. etc.
SUPRAGTE
North Sydney
Re: Just installed Walbro 550HP fuel pump Sun, 25 May 2003 11:30 Go to previous messageGo to next message
Noise suppressors are to stop interference coming into things like your car stereo to stop whistle and high pitch noise. They're only actually a capacitor.
They won't help you with your fuel pump at all.
SupraPete
Re: Just installed Walbro 550HP fuel pump Sun, 25 May 2003 11:45 Go to previous messageGo to next message
Ahh ok.
So why is my fuel pump so noisy (I can hear it)?
Stenno
Re: Just installed Walbro 550HP fuel pump Sun, 25 May 2003 11:57 Go to previous messageGo to next message
I've been running that pump for over 6 months, it buzzes away pretty loudly, but like wise, does the job well for such a small looking pump (compared to the factory mk3 pump).
I paid $254 for mine.
rvrolla
Central Coast
Re: Just installed Walbro 550HP fuel pump Sun, 25 May 2003 12:56 Go to previous messageGo to next message
Stenno: Are you coming to Dyno Day mate? I'd love to see your 2JZ powered monster!!
SUPRAGTE
North Sydney
Re: Just installed Walbro 550HP fuel pump Mon, 26 May 2003 10:39 Go to previous messageGo to next message
Stenno:How much power is she putting out with that pump? What pressure are you running it up to?
I'm thinking i might have to run a fuel pump resistor and have it activated below say 3500rpm an up to 0psi to drop the flow which will also drop the noise. I'll do it through one of the outputs on the Microtech.
Pete: Just the way they are mate, noisy little buggers. It's almost definitly a bigger performance type pump. You could check it's wired through the fuel pump resistor or wire it through one like i'm going to do and have it activated when your giving it some stick.
Re: Just installed Walbro 550HP fuel pump Mon, 26 May 2003 13:56 Go to previous messageGo to next message
I have a Walbro as well, and yes it buzzes away quite audibly when the car isn't moving. It seems to keep the 2JZ running though so I'm happy. Smile
SupraPete
Re: Just installed Walbro 550HP fuel pump Tue, 27 May 2003 03:30 Go to previous message
Looking into my fuel pump a bit more, mine cannot possibly be standard. With the amount of noise created is a big one. But more importantly, my injector duty cycle at 7,000 revs (peak power at 5,500 don't know what the DC is there) is only 58%!! Must be supplying more pressure then standard, and the FPR I'm using (standard 1U) mustn't be working properly - one of the return lines is bent!
Previous Topic:Boost guage fitment?
Next Topic:What muffler for 4AGE?
Current Time: Mon Oct 12 22:33:14 UTC 2026
Total time taken to generate the page: 0.12132501602173 seconds
