Toymods » General Car Talk » Rust ....
gearb0x
Rust .... Sun, 25 May 2003 10:16 Go to next message
hey :0
there is a bit of rust forming in the T-18 and i wanna fix before it gets to bad..
allong the side window sills i boged when i done the home respray but its comming through in a bad way...
this is where u guys come in Wink ..
I want to weld it (1. to learn, 2. bogs gay) i was wondering if you people have any links to build ups with a lot of rust and intense pictures of the rust being notrusted(tm) Wink
ive found a few and they are very interesting to see how people fabricate metal, just wondering if you people had any to share...
Re: Rust .... Sun, 25 May 2003 11:18 Go to previous messageGo to next message
easiest way is to find a wreck with a good body, cut off the pieces you need (measure 5 times, cut once so you get it right). then weld into place.
gearb0x
Re: Rust .... Sun, 25 May 2003 12:59 Go to previous messageGo to next message
hehe
most T-18 wrecks are non existant under the sie back windows Wink
i got one out the back i can almost fit my head in the rust hole Shocked
ra23celicachick
Mornington Peninsula
Re: Rust .... Sun, 25 May 2003 22:48 Go to previous message
My dad has done some work on my Celica with fixing up rust. Basically he cut the whole section of rust out and took it back to where the solid metal was. got some sheets of metal, cut it to size and basically used a hammer and a bit of railway track and moulded it to the right shape. He slid the piece of metal in behind the original metal to fill the hole then welded it in.
He ground back the lumps and then filled it with metal mend. Once that was set ground that fairly smooth and then put a thin layer of bog to get a smooth finish.
Can't tell that the hole was there!
Good luck Smile
Previous Topic: Question: Push Delivery of AWD & 2WD ???
Next Topic:Whats with the stickers down the side?
Current Time: Thu Oct 29 14:48:56 UTC 2026
Total time taken to generate the page: 0.064549922943115 seconds
