Toymods » Tech & Conversions » Brake rotor/caliper asembly to fit under MA61 wheels
BlackSupra
Brake rotor/caliper asembly to fit under MA61 wheels Sun, 25 May 2003 12:33 Go to next message
Any make and model.
Im thinkig about brakes and trying to scope out if there are any rotor/caliper paackges superior to that of a MA61 off a late model car that will 'almost' bolt straight up behind the stock 14 inch rims, with some minor bracket engineering?
ta guys
[Updated on: Mon, 26 May 2003 00:05]
Re: What cars came with a 4x114.3 hub? Sun, 25 May 2003 12:58 Go to previous messageGo to next message
Hmmm... if you want to keep your 14" rims, I can't see you getting huge improvements over the stock brakes. The only real problem with MA61 brakes is the rotors are too small, but if you want to get them much bigger you'll need bigger wheels to fit them in.
BlackSupra
Re: What cars came with a 4x114.3 hub? Sun, 25 May 2003 13:30 Go to previous messageGo to next message
THis is true, but im sure there are improvements to be made through alternative calipers.
From a search through the entire DBA catalogue i have found this out:
MA61 Front rotor (vented)
Diameter: 258mm
Height: 26mm
Thickness: 20mm
Center Hole: 76mm
Now ive found the following which are similar:
Nissan Nomad GC 22 Van 1986-93 (vented)
Diameter: 250mm
Height: 30mm
Thickness: 22mm
Center Hole: 73mm
Ford Capri SA, SC, SE Convertible (Turbo models) 89-94
Ford Laser KE 2wd & 4wd Turbo 87-90
(share the same rotor)
Diameter: 260mm
Height: 32mm
Thickness: 18mm
Center Hole: 75mm
Now the question is, how much better or worse will the brakes be on these cars? and ill have to find out if they have 114.3 PCD.
Re: What cars came with a 4x114.3 hub? Sun, 25 May 2003 13:56 Go to previous messageGo to next message
Short answer....I'd use neither.
For all the bullshit you'll have to go thru to fit them and get a decent caliper, you haven't even increased rotor diameter, so you won't get any extra 'leverage' effect.
You should be able to squeak in a 280-285 mm rotor under your 14" wheels (early Falcons had 287 mm rotors under a 14" wheel) with a bit of sussing out. I was able to sneak some MA70 rear brakes (291mm) under a Ford XF wheel.
Don't worry too much about the PCD of the rotor either....find a suitable rotor, buy them undrilled and get the machining done to suit your 114.3 PCD.
Aren't there 15" versions of the MA61 mags? You could fit 305mm rotors then.
[Updated on: Sun, 25 May 2003 13:58]
BlackSupra
Re: What cars came with a 4x114.3 hub? Sun, 25 May 2003 14:22 Go to previous messageGo to next message
Never thought of that dave!
hmmmm...doh means i gotta go back through the catalogue!
there doesnt seem to be an awfully large amoutn of clearance betweenthe stock caliper and rim though?
I would have thought brakes off the 94 turbo capri would be alright and perhaps better than the supra, then again maybe not.
BlackSupra
Re: What cars came with a 4x114.3 hub? Sun, 25 May 2003 14:23 Go to previous messageGo to next message
Oh, the idea was to use both the caliper and rotor off the capri, because they should fit under the rims.
15inch rims are only 6 inches wide, i like 7inches.
[Updated on: Sun, 25 May 2003 14:24]
BlackSupra
Re: What cars came with a 4x114.3 hub? Mon, 26 May 2003 00:17 Go to previous messageGo to next message
Here are a few more options, taking Dave's advice, ive ignored the PCD and based this upon rotor diameter and the height of the hub.
Ford Courier 2.6L 4WD 87-98
Diameter: 272
Height: 25
Thickness: 22
Center Hole: 93
Holden Jackaroo Monterey UB 3.5L ABS 98+
Diameter: 280
Height: 36
Thickness: 26
Center Hole: 87.5
Lotus Elise (YUM)
Diameter: 280
Height: 29.3
Thickness: 26
Center Hole: 56.6
Mazda 4wd B Series (B200D, B220D, BB260D) 85-96
Diameter: 272
Height: 25
Thickness: 22
Center Hole: 93
Peugeot 306 N5 Series 1 GTi-6 97-99
Diameter: 283
Height: 27.5
Thickness: 22
Center Hole: 66
Peugeot 406 97+
Diameter: 283
Height: 28.2
Thickness: 26
Center Hole: 66
Volkswagon Golf VR6
Diameter: 280
Height: 28.2
Thickness: 22
Center Hole: 65
demuire
Ipswich
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 01:41 Go to previous messageGo to next message
Early Falcons had 287mm rotors under 14" rims? Where did the caliper go???
Wow. I have 266mm rotors on mine (unvented) and I have very little space between caliper and wheel, and my calipers aren't exactly huge or anything...
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 02:15 Go to previous messageGo to next message
Ultimately, the size rotor one can fit under a wheel depends on a few things:
  1. rotor height
  2. wheel offset
  3. wheel construction/diameter, and
  4. caliper profile.
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 02:24 Go to previous messageGo to next message
Dave, haven't caught you on ICQ lately, so I'll leave it here.
How does this sound?
DBA Slotted rotors for a Lotus Elise
280mm diameter, 26mm thick, overall height very close to Mk2 Supra
Only $116 each from Autospeed too.
VT Commodore onwards 2-piston calipers
Cheap, common, more effective than MA61 and can fit the thicker disc.
Rear use factory brakes, just make sure they're in good condition.
DOT5.1 fluid and then see how the bias is. Sound ok? I was thinking about this for a cheap solution for bigger brakes that'd have no problems fitting under a 15" wheel.
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 03:22 Go to previous messageGo to next message
Might be OK, but I'd just check the construction of the disc....Lotus Elise is about 2-300 kg lighter than a Supra. Check the hat section - make sure it's nice and thick otherwise it might be prone to cracking. Also you might want to do a test fit - scum some dead rotors from your local Lotus dealer, machine the central hole to fit your hub and have a see.
Also you'll need to check the radial depth of the rotor vis a vis the VT two spot pad. Not at all familiar with the Commodore stuff, but I'm not sure they'd be the most slimline calipers around. You'll almost certainly have to fabricate a caliper bracket.
I probably wouldn't touch the rears other than to make sure they are in good working order (even though it's really easy to do 300+ mm upgrades!). Dot 5.1 is great, and the Motul stuff is $4-5 cheaper than the AP atuff.
[Updated on: Mon, 26 May 2003 03:33]
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 06:00 Go to previous messageGo to next message
Hmm, reckon they'd give one up?
It was just a thought, I'm going to get a set of new DBA Slotted rotors, some decent pads and bleed the brakes with some DOT5.1 brake fluid. Should be good enough for the street, but if anyone comes up with another good budget fluid, i'm all ears.
BTW, anyone recommend a good pad for the Mk2 calipers?
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 06:36 Go to previous messageGo to next message
I'm pretty happy with my EBC pads so far. Greenstuff on the front and Blackstuff on the rear (that's all they had available).
SUPRAGTE
North Sydney
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 10:55 Go to previous messageGo to next message
Frankie,
I just put some new DBA slotted rotors on the front and flushed completely with 2 bottles of 5.1 Motul. I'm using Metal king pads.
It didn't really help!
I'm all ears for a brake upgrade option Smile
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 11:10 Go to previous messageGo to next message
I'm listening too!
the stockers are adequate. just.
stopping from anything more than 50km/hr, I'm not at all happy with them. which is unfortunate considering how often I am doing more than 50km.hr Smile
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 11:14 Go to previous messageGo to next message
I've been thinking about this, are both of you intent on keeping the 14" MA61 wheels? As GT once described before, they have a very small X-factor meaning the the brakes fill a lot of the rim even though they aren't that big.
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 11:18 Go to previous messageGo to next message
I'm keeping it for a while
but if it means fitting bigger brakes, I'd be happy to get some 16's
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 11:21 Go to previous messageGo to next message
Once the assignments are over, I'll have another look. I don't wanna go any bigger than 15's, so I'll see what I can dig up.
BlackSupra
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 11:42 Go to previous messageGo to next message
I did some hunting around and it seemed that if i could get DBA rotors for a Ford econovan with no center hole drilled or for the studs, one could have the rotor to fit under the rim (i hoped)
the rotor is 275mm but is the same thickness, so you could use the stock caliper if it was relocated on a new fabricated bracket.
it was purely an issue of clearance then. There is about 10mm between the caliper and rim, but the caliper sits right on the lip of the wheel where it becomes a little smaller upon the internal diameter. This could be resolved by the fact that the height of the econvan rotor was 7mm taller, thus pushing the rotor face back from the lip, giving more clearance.
Supposedly, 'frankie' in talks with the DBA fella on PF.com found out that the center holes are pre drilled.
Ive sent them an email to confirm this, but if it fits under the rim with the stock calipers we may be able to convince them to do a custom line run?
Anyways, it was just a thought.
P.S econovan rotors also come in the slotted variant
[Updated on: Mon, 26 May 2003 11:45]
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 11:43 Go to previous messageGo to next message
I'd be wanting more surface contact from my calipers.
otherwise I wouldn't be bothering with a new rotor
BlackSupra
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 11:48 Go to previous messageGo to next message
The bigger rotor will aid in cooling a little bit.
However i see your point, but we are severly kicking ourselves in the ass saying we want brembo braking power under a 14inch rim.
Alternatively, by running through the DBA catalogue one can find which rotors are 20mm thick and then utilise those calipers.
Unless we go 15 or 16inch, we are pretty limited.
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 11:51 Go to previous messageGo to next message
From what I can remember, you guys have a bit of inboard space. I suspect what you guys are going to need to do is run a fairly tall rotor so that you can fit a big rotor/caliper combo under your restrictive wheels. Try and find a slimline caliper if at all possible - this will help enormously.
BlackSupra
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 11:53 Go to previous messageGo to next message
Tall rotor? Confused
Do tell Dave.
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 11:59 Go to previous messageGo to next message
Something with a big hat dude. And Dave, you were right about the Lotus discs being too flimsy.
BlackSupra
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 12:10 Go to previous messageGo to next message
Ah ok, that was the 'lip' on the wheel i was talking about, the inboard space gains almost gains 20mm in diamter i beleive from a rough guess lacking measureent equipment.
Thats was hopefully solved by the 7mm taller econovan rotor
BlackSupra
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 13:37 Go to previous messageGo to next message
Ok, heres the best option so far.
Mercedes Benz A Class Rotor from a A190.
Diameter: 276mm
Height: 36mm
Thickness: 22mm
Center Hole: 67mm
This means the height is 11mm taller, which should clear the lip in the rim easily.
The bolt hole which will be drilled can be machined out to the stock 76mm.
The rotor is 2mm thicker now so another 'slimline' caliper will be required.
Alright, so how does one go about sourcing a slimline caliper for a 22mm disc?
ed_ma61
Lost in the K hole
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 13:51 Go to previous messageGo to next message
im wayyy to drunk atm to get into thisk, but suffice to say: if youre going to the effort to make a custom caliper adapter and custom rotor mounts etc, just bite the friggin bullet, and go 315mm+, big 4 spots and larger rims. for the effort/reward. i say screw it , and do it properly....
screw the fucking around for the 20mm dia gains and maybe 1 extra piston... go 50-60mm gains and 4 piston!!!
in the end, save up the cash, ita babout the same effort, and you get MASSIVE performance increase...
ed
rob_RA40
c'town, NSW
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 22:03 Go to previous messageGo to next message
me fail english, thats umpossable... Cool
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 22:42 Go to previous messageGo to next message
LOL @ Ed Laughing
He's right though. If you're going to all this effort, you might as well go all the way. Those big Wilwood rotors Ed was looking at aren't expensive, in fact they're cheaper than the slotted DBA rotors I bought not long ago!
Re: Brake rotor/caliper asembly to fit under MA61 wheels Mon, 26 May 2003 23:46 Go to previous messageGo to next message
Exactly, wheels are a one off cost. If you are going to the trouble of doing a big brake upgrade and spending $40 on brake fluid every time you do a bleed, don't you want decent tyres too?
Save up and get some brakes that you can be confident will work MUCH better than what's there now. I'd be aiming for 300 mm as a MINIMUM. Any less and I think you'd be wasting money and time.
SUPRAGTE
North Sydney
Re: Brake rotor/caliper asembly to fit under MA61 wheels Tue, 27 May 2003 09:31 Go to previous messageGo to next message
It may be difficult for some to understand but I don't want to get rid of the factory 14's. I think they're awesome and very important to the look of the classic Supra. Therefore it's important for me and a few others who don't want to hack up the car to keep it looking as standard as possible, ie keep the wheels.
Why not a 2 or 4 spot Nissan caliper with bigger pad surface area?? Or something along those lines?
BlackSupra
Re: Brake rotor/caliper asembly to fit under MA61 wheels Tue, 27 May 2003 10:18 Go to previous messageGo to next message
Im in the same boat as paul, i love the stock rims and im in no such way able to afford the only mag wheel i would put on the supra: Simmons OM17's.
So without upgrading the $3000 rims or converting to 5 stud (which has anyone completed yet??) my rims aren't getting any bigger.
Im just trying to get decent brakes under the stock rims.
Yes i know, its a big investment for a small gain, but:
A) the limitation is the 14inch rim
b) i cant afford the rims required to fit the brakes
c) anything bigger will be better than stock
Purple_Beasty
New Zealand
Re: Brake rotor/caliper asembly to fit under MA61 wheels Tue, 27 May 2003 10:25 Go to previous messageGo to next message
Is anyone here using brake ducting on their road cars?
If set up right it can be quite beneficial and you can minimise the amount of water sprayed onto the rotors in the wet. It will wear you pads and rotors faster due to the dust and dirt etc sprayed onto the rotors. Also very CHEAP.
demuire
Ipswich
Re: Brake rotor/caliper asembly to fit under MA61 wheels Tue, 27 May 2003 11:39 Go to previous messageGo to next message
Is there any real problem in cutting out the stone guard behind the disc? I've seen it done on several race and rally cars, with with the amount of dirt thrown up by rally cars...
What's the best way to build ducting to the discs?
Re: Brake rotor/caliper asembly to fit under MA61 wheels Tue, 27 May 2003 11:40 Go to previous messageGo to next message
how wide are those simmons 17's?
I would not want any less than 8" if I was buying a new rim (especially at that price).
admittedl;y I love the stock rims, but in terms of handling and brakes, I'm willing to sacrifice it (and increase the stealability of the car)
BlackSupra
Re: Brake rotor/caliper asembly to fit under MA61 wheels Tue, 27 May 2003 11:56 Go to previous messageGo to next message
Your choice of:
17x6 -> 17x10 inches
I wouldd go black centers of course Smile
Re: Brake rotor/caliper asembly to fit under MA61 wheels Tue, 27 May 2003 12:06 Go to previous messageGo to next message
and the 17x10 fit on the supra?
that's a bit of a pain. Ideally I'd *love* 17x8 on the front and 17x10 on the back (well, I'd prefer 16s, but beggars cant be choosers)
10" on the front is too big, and 6" on the front is definitly too small
or does the -> mean they do everything in between?
BlackSupra
Re: Brake rotor/caliper asembly to fit under MA61 wheels Tue, 27 May 2003 12:12 Go to previous messageGo to next message
everything in between my friend
and yes 16x6 -> (to) 16x10 in the same designs
17x8, 17x9 Simmons OM custom wheels. 10mm offset front, 0mm offset rear.
http://www.celicasupra.com/images/river3.jpg
Re: Brake rotor/caliper asembly to fit under MA61 wheels Tue, 27 May 2003 12:18 Go to previous messageGo to next message
I think I just made a mess in my pants.
BlackSupra
Re: Brake rotor/caliper asembly to fit under MA61 wheels Tue, 27 May 2003 13:13 Go to previous messageGo to next message
Would you like some tissues?
Ok how does this sound
Mercedes A class A190 Disc with Mazda RX7 Series 4 N/A calipers
ill have to see how they measure up
Re: Brake rotor/caliper asembly to fit under MA61 wheels Wed, 28 May 2003 00:47 Go to previous messageGo to next message
Norbie,
If you don't mind me asking, how much the EBC pads cost you?
BlackSupra
Re: Brake rotor/caliper asembly to fit under MA61 wheels Wed, 28 May 2003 01:03 Go to previous messageGo to next message
And a product number would also be tops Smile
Re: Brake rotor/caliper asembly to fit under MA61 wheels Wed, 28 May 2003 01:52 Go to previous messageGo to next message
To be honest I have no idea, I bought them ages ago... I'll see if I can dig up a receipt when I get home. They weren't cheap from memory.
Re: Brake rotor/caliper asembly to fit under MA61 wheels Wed, 28 May 2003 01:55 Go to previous messageGo to next message
That'd be great if you can. Wasn't expecting them to be cheap, but based on the EBC site, and how I drive, I reckon I can get away with changing them once a year, not as if my car is going to see any track work. Very Happy
Re: Brake rotor/caliper asembly to fit under MA61 wheels Wed, 28 May 2003 06:02 Go to previous messageGo to next message
that is the sexiest ma61 I have ever seen
Re: Brake rotor/caliper asembly to fit under MA61 wheels Thu, 29 May 2003 05:30 Go to previous messageGo to next message
excellent
the simmons actually come in 15" to 18" diameter, and up to 13" wide.
a set of 16" with tires cost around $3500.. which will do me nicely.
when I looked on that website you posted, I saw US$3100 as the price tag, and that was a BIG turnoff. but since it looks like only being that in AU$, I can handle it
BlackSupra
Re: Brake rotor/caliper asembly to fit under MA61 wheels Thu, 29 May 2003 06:47 Go to previous messageGo to next message
I love the rims, they are tops
Just seems a bit hard to justify rims that are worth as much as the car, thats all.
If i was made of money then no worries!
WTF!!! Shocked 13inches wide, id like to see traction lost with them!
[Updated on: Thu, 29 May 2003 06:50]
Re: Brake rotor/caliper asembly to fit under MA61 wheels Thu, 29 May 2003 07:17 Go to previous messageGo to next message
I'm not made of money either.
but I did just find a good use for my tax return Smile
but then I think about what else I could do with $3500.... we'll see.
quite direct from simmons: $2390.22 for 16x8 fronts and 16x9 rears
about $200 more for 17" in the same specs
[Updated on: Thu, 29 May 2003 07:18]
Re: Brake rotor/caliper asembly to fit under MA61 wheels Fri, 30 May 2003 03:02 Go to previous messageGo to next message
justcallmefrank wrote on Wed, 28 May 2003 10:47
Norbie,
Bah! I've looked through my entire stack of receipts and other crap (took me all night) and couldn't find it. Sad
Jonny2TG
Tasmania
Re: Brake rotor/caliper asembly to fit under MA61 wheels Sat, 31 May 2003 14:00 Go to previous messageGo to next message
I think you have used the DBA catalog in a wrong way and been mis-led a bit. With 14" wheels, you have to keep the disks you have. You would only get a adavnatage with new disks if they where thicker, and then you would need the matching calipers, and both disk and caliper converion plates. You best keep your brakes and get better pads. Also, maybe new slotted rotors from DBA, to suit RA60.
Or you can use 4wd HiLux 4 spot calipers on your original disks. With RA60 and hilux disks are 20mm thick, so the hilux 4spots can be used on the RA60 disks. This is what I am doing, not finnished yet. A converion plate may be needed. Not sure of the performace difference yet.
Re: Brake rotor/caliper asembly to fit under MA61 wheels Sat, 31 May 2003 15:08 Go to previous message
No, he hasn't used it wrong, he was looking for a rotor that was a larger size that would still fit under the 14" rim.
Previous Topic:What does a 1.8 3TGTEU come out of?
Next Topic:will ra60 brakes bolt up 2 my st141
Current Time: Thu Nov 19 00:24:09 UTC 2026
Total time taken to generate the page: 0.0157470703125 seconds
