Toymods » Tech & Conversions » clutch?
tim123c
clutch? Mon, 26 May 2003 01:25 Go to next message
Hi guys, just wondering if the clutch on an AE92 4agze is the same as the non-supercharged 4age?
Thanks.
tim Very Happy
celicaboy
Re: clutch? Thu, 05 June 2003 11:31 Go to previous messageGo to next message
they use the same clutch... the 4agze one is just a lil heavier.. so they are interchangeable
FLYNSX
    flyn
Re: clutch? Fri, 06 June 2003 01:20 Go to previous messageGo to next message
Well from what BD4'S told me that did my conversion there not the same i was running standard 4age box on the supercharged motor lasted 3 weeks the box then got a 20v lsd box and they told me i had to change the clutch as well.
Levin4Kevin
Sydeny
Re: clutch? Fri, 06 June 2003 07:04 Go to previous messageGo to next message
Tim,
As I am sure you probably know this by now, but they are definately different,10mm bigger. Still waiting on that email about your half cut and some possible parts. Thanks, Kevin
P.S. I paid $320 for my heavy duty Daikin clutch kit.
celicaboy
Re: clutch? Fri, 06 June 2003 10:58 Go to previous messageGo to next message
actually we done a clutch on a 4agze today.. they used the 4age clutch and modified it for the 4agze Smile it worked well
Re: clutch? Fri, 06 June 2003 12:15 Go to previous messageGo to next message
If the clutch had to be modified and its heavier, then its not the same clutch now is it?
Joshstix
Toymods Vice President
Re: clutch? Mon, 09 June 2003 02:05 Go to previous message
The GZE flywheel and GE flywheels are totally different. The GZE has posts cast into the flywheel for the Pressure plate to mount to so the plate is much flatter rather than having the hump needed to be able to bolt down to the same level as the friction face of the flywheel and still have space to be able to allow clearance between the pressure plate and the friction plate when the clutch is disengaged.
Sure you can use the GE flywheel and clutch setup on a GZE but it's not what the engine came with, and the original question was asking if the AE92 GE and GZE had the same clutch.
Please refrain from spouting random drivel in the name of advice in area's where your knowledge is obviously lacking.
Previous Topic:89 Celica Issue
Next Topic:AE86 Accelerator cable
Current Time: Fri Nov 20 00:42:43 UTC 2026
Total time taken to generate the page: 0.0089020729064941 seconds
