Toymods » Tech & Conversions » GA70 + 1JZGTE conversion - few questions
Rattlehead
GA70 + 1JZGTE conversion - few questions Mon, 26 May 2003 07:05 Go to next message
Nearly in the closing stages of finding a half cut. Still need to decide on manual or auto - but I think it might be auto, only because my car is a daily driver, and I get stuck in traffic a fair bit.
Anyway, few questions.
I have to decide whether to take my car to a normal mechanic or a performance workshop.
Normal mechanic coversion will cost around the $400 - $1000 mark. P/Workshop around $3000 - $7000.
I'm really only going to remove my 1G and putting the 1JZ in...
Also, I don't know what changes I'll need to make to the rear end. From what I've been told...I need to mod my tailshaft or get a new one, change the diff, fuel pump.
Anything else? I need to make an order of my half cut with other parts I require, so it'll be ready by August for fitting.
Thanks...
rob_RA40
c'town, NSW
Re: GA70 + 1JZGTE conversion - few questions Mon, 26 May 2003 09:49 Go to previous messageGo to next message
you wont need to change the diff unless you have a single spinner and really want LSD..
you might be lucky with the tailshaft
check the part number of the fuel pump (go to toyota dealer) if it is the same as the MA71 or JZA70 then leave it in
you have a very good platform for a conversion u will find that you wont have to change much at all.
rob_RA40
c'town, NSW
Re: GA70 + 1JZGTE conversion - few questions Mon, 26 May 2003 09:54 Go to previous messageGo to next message
whoops almost forgot
use the radiator from the front cut, the 1G-GE GA70 has a piss small single core piece of tin that wont even cool a 5M-E
Rattlehead
Re: GA70 + 1JZGTE conversion - few questions Mon, 26 May 2003 10:03 Go to previous messageGo to next message
Thanks Rob - thats the best thing I've read all day!!!
Everyone else is telling me to buy a new car - whats with that??
Question still remains...will a normal mechanic be able to perform this conversion? Can't see why not...any opinions?
knackers
berala sydney
Re: GA70 + 1JZGTE conversion - few questions Mon, 26 May 2003 11:43 Go to previous messageGo to next message
hi
should'nt be to much prob with the conversion the normal mechanic will beable to do the job not that much involved.
cya knackers
Re: GA70 + 1JZGTE conversion - few questions Mon, 26 May 2003 11:53 Go to previous messageGo to next message
only hassle will be the wiring.
it's probably beyong a standard mechanic to fix... you'll either have to pay someone ($$$), or do it yourself. you might be able to find someone on the forums to help you out, if you ask nicely or offer a small monetary/beer incentive.
if you've got a decent grounding in electronics, you should be able to do it yourself (f you dont, dont try it!)
Re: GA70 + 1JZGTE conversion - few questions Mon, 26 May 2003 13:55 Go to previous messageGo to next message
Any mechanic should be able to physically install the engine and transmission, it's certainly not a difficult task. Hell if a backyard hack like me can do it I'm sure it's not beyond a professional spanner-twirler! However as draven said, actually getting the thing running might be a different story - you might be better off talking to a few auto sparkies in your area. Again it's not that hard if you know what you're doing, but if you don't know what you're doing it's easy to screw it up.
Rattlehead
Re: GA70 + 1JZGTE conversion - few questions Mon, 26 May 2003 15:02 Go to previous messageGo to next message
Okay, so the main problem will be the wiring.
So it's not as easy as pulling out certain sections and installing them?
I guess not...
So would it be wise to pull the loom apart, and get it sent to Sixworks or someone similar to sort it, and that way the mechanic can install the wiring? Or is it still better to have the mechanics get an auto electrician in just to fit the wiring?
Thanks...
Stenno
Re: GA70 + 1JZGTE conversion - few questions Tue, 27 May 2003 00:12 Go to previous messageGo to next message
Norbie wrote on Mon, 26 May 2003 23:55
Hey! I had NFI what I was doing and I got my shitbox running Razz
Seriously, going from a GA70 to a JZA70, IF you have a complete front cut, it will be a piece of cake. All you need is a bit of competance and can turn a spanner, you could have the swap done in a couple of days pending the tailshaft.
You will probably have to swap over the crossmembers too
Rattlehead
Re: GA70 + 1JZGTE conversion - few questions Sun, 01 June 2003 06:00 Go to previous messageGo to next message
Another question...I'll need an LSD diff...can someone pelase tell me the size and ratio and whatever else I need to know??
Thanks... I'm going to place my order tomorrow, so if theres any last minute parts I'll need from an importer ... help me out!!
Appreciate it all...it's finally gonna happen *touches wood*
(I've always had bad luck when it comes to wanting to do something)
rob_RA40
c'town, NSW
Re: GA70 + 1JZGTE conversion - few questions Sun, 01 June 2003 22:15 Go to previous messageGo to next message
you will NOT NEED and LSD diff but it is preferable...
so if u dont have money for the diff put it on the low priority list cause u can live with a single spinner to get the car on the road if u have budget or time constraints... if u can afford it then by all means upgrade...
check your build plate in the engine bay it should have a trans axle code that looks like G305....
thats a supra G series diff which u should have... check your code and then go here to find the ratio etc
url will be in next post.......
rob_RA40
c'town, NSW
Re: GA70 + 1JZGTE conversion - few questions Sun, 01 June 2003 22:16 Go to previous messageGo to next message
http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/AxleCodes.html
Rattlehead
Re: GA70 + 1JZGTE conversion - few questions Mon, 02 June 2003 14:13 Go to previous messageGo to next message
Thanks Rob! You've been really helpful
Okay, well, the code is G252
So by going by the site..
It's an 8" 4.556 2 pinion non LS diff I got. Right?
So ... does that mean I need to get myself an 8" LSD diff?
I got told that the power of a 1JZ will be too powerful for my diff and it'll blow and I'd be spinning all the time...
hehehe, wish I knew more. But yeh...I guess if I dont need it right away, then it can wait.
Re: GA70 + 1JZGTE conversion - few questions Mon, 02 June 2003 19:48 Go to previous messageGo to next message
it depends how you treat it!
if you just want to get your caron the road, and you think you can resist the urge to use the 1jz's potential, then your diff will be fine.
but if your foot gets anywhere near the floor, expect to tear up 1st, 2nd and 3rd with ease
Re: GA70 + 1JZGTE conversion - few questions Mon, 02 June 2003 23:20 Go to previous messageGo to next message
The diff you have will handle the power, ie it won't just "blow up" provided you don't abuse it of course. Having said that, you'll have big problems getting your power to the ground without an LSD centre, so it would be a good idea to chuck an LSD in if you can afford it.
Rattlehead
Re: GA70 + 1JZGTE conversion - few questions Tue, 03 June 2003 05:21 Go to previous messageGo to next message
lol - u guys are great.
Thanks for all the info.
Now I just to wait for a JZA70 half cut to come around.
John from Rolin has told me that they dont take holding deposits...but will let me know if they get one.
So hopefully all goes to plan and they find me one and let me know about it.
Otherwise I'll just have to get it from somewhere else.
I think I got all the info I need. Thanks!!
Rattlehead
Re: GA70 + 1JZGTE conversion - few questions Sat, 07 June 2003 14:46 Go to previous messageGo to next message
Back form the dead again...prolly the last time.
Quick question - Do I need to remove the whole dash to get the 1JZ wiring in my car??
http://www.supras.nl/images/1jzdashboardworkb.jpg
Just this pic has gotten me really worried.
I'm going to see the mechanic I'm planning to get my conversion done from on Monday and will pretty much print out this website and the pictures to see if he's confident enough he can do it still.
http://www.supras.nl/view.php?page=1jzswapmarcel.h tm
I know he can ignore the wiring lengthening process...everything seems straight forward cept for the part to get the 1JZ dash connectors installed in the car. I would prefer to use the dash that comes with the half cut (esp if its digital) ... so would the whole dash need to be removed? Or does it need to be removed anyway to get the ECU and wiring in there? With the glovebox removed is there enough room to remove old ECU/fit new ECU and run the wiring etc etc???
Another question...how much difficult/easier would this swap be compared to a swap in a Commodore, Falcon, Magna??? He says he's done numerous swaps on those kinds of cars...electrics and all. So I guess that might be as far as he's gone in terms of engine conversions. Dunno what engines...but would it be similar?
Also, I know Grant (Sixworks) does something with the wiring. How can his service help me? From my understanding, he sorts wiring so that everything is plug n play. Does that mean that he will sort the wiring so that the 1JZ wiring is connected to the existing wiring in my car so that I use the same dash already in there? Or does he simply sort the wiring so that everything is loomed up and labelled so that an installer will know where to run each section?
Please help me understand wiring a bit more...because this is as far as I understand it.
1. Wiring from engine bay etc goes to ECU
2. Other wires go to the dash, instrument cluster.
lol...not very far. I'm also confused about other wiring, because theres wiring around the fuse box at the foot area of the drivers side. Now I've been told that this is not required to be changed. However, a few things seem to go through this fuse box ... Is this wiring separate to the wiring of the engine to the ECU? I take it the wiring and electrics that go through this fuse box are accessories? like lighting, head unit? Therefore the wiring removed from my engine bay will be the ones attached to the engine? Things like wiring that go to my headlights will be left alone...right??
Thanks heaps guys - I know thats a lot of questions, but I dont want to get ripped off. Or be left with a non running car with a lot of mess I have to sort out.
[Updated on: Sat, 07 June 2003 15:14]
AmperSand
Re: GA70 + 1JZGTE conversion - few questions Thu, 12 June 2003 02:38 Go to previous messageGo to next message
Umm..
I have a GA70 supra i did a 1JZGTE conversion into.
Used to be an air/air IC 1GGTE GA70.
I have that same diff.. G252
With the Auto box i have, it rev limits in overdrive @ 160km/hr (cant even get to the end of the 1/4 mile.. like 40 metres short)
Has some wicked acceleration.. My diff has always had a bit of slack since i got it.. i still havent blown it in over a year and a half, and just over 8months worth of 1JZGTE power driving Smile
I've had my turbos rebuilt with steel turbines, and have a 3" mandrell bent exhust with 3" straight through muffler.
Dyno'd 182.1rwkw (its not even getting 1:1 drive ratio in overdrive afaik)
And yes, you have to remove the whole dash Razz (at least we did anyway)
I got my mechanic to do the swap, and got an auto ellecy in through him to get most of the loom done.
Cost $2000 in labour (inc tailshaft, auto service kit and a few other things)
$1950 for halfcut
$800ish for auto ellecy (got my aircon all redone also)
and around $2500 for turbo rebuild Smile
Any questions, just PM Very Happy
Todd
[Updated on: Thu, 12 June 2003 02:40]
lumpy
Adelaide, SA
Re: GA70 + 1JZGTE conversion - few questions Fri, 13 June 2003 08:12 Go to previous message
I did the conversion from 7M GE to 1jz in the ma70 and agree - you have to take the dash out.
Getting it to run is one thing, getting all working sweetly and well is another. My dad did the wiring - he's a bit of a perfectionist electronics tech and most of the time was spent sorting out which wire went where onto the 1jz computer from the MA70 wiring (things like speed sensor from the speedo to ECU, TEMS controllers, air-con etc). If you have a front cut it'll be easy for the engine harness etc - it's just connecting it up with the ma/ga70 inputs/outputs that can be tricky. Also the engine bay wiring for the fusebox etc needed to be swapped for the jza70 setup.
Good Luck - it is worth it. And get an LSD if you can. I've got the 4.3:1 LSD, and with the R154 5 Speed it does 110 Kph in 2nd, 150Kph in 3rd at the redline. And hits the 180Kph speed cut in 4th,5th Crying or Very Sad Getting traction is the largest issue !!Laughing Laughing
PS Coz I'm a bit of a perfecionist too the wiring is all plug and play - with the plugs from the jza70 tapped into the ma70 harness - I could unplug the 1jz + ECU and plug the 7M back in if I really wanted too!
[Updated on: Fri, 13 June 2003 08:16]
Previous Topic:Still searching for bigger brakes for GZ20 Soarer
Next Topic:1ggte *TRD* bits
Current Time: Sat Nov 21 00:13:49 UTC 2026
Total time taken to generate the page: 0.0064640045166016 seconds
