Toymods » Tech & Conversions » Remove steer wheel on ke11?
Ruckus
Melb
icon5.gif  Remove steer wheel on ke11? Mon, 26 May 2003 07:20 Go to next message
Can someone please enlighten me on the art of removing a stock steeringwheel off a ke11/10. There appears to be no screws like on my ke20, i don't have a clue.
please help.
[Updated on: Mon, 26 May 2003 07:22]
Re: Remove steer wheel on ke11? Mon, 26 May 2003 07:38 Go to previous messageGo to next message
well, it aint that bad because there are no collapsible columns to damage Smile
loosen the nut off a little bit (like 1mm gap between nut and washer) not too much so you don't whack your nose..
hold onto one of the horizontal bits from the centre to rim, pull back on it, and whack the same position on the other side, so you sort of forcefully lever it off. you can put a fair bit of effort into it and it should come off...
the dodgy way is to loosen the nut to only just loose (still on the spring washer) and drive around a bit till it loosens Wink
good luck.
Ruckus
Melb
Re: Remove steer wheel on ke11? Mon, 26 May 2003 07:58 Go to previous messageGo to next message
yeah thanks but how do i get to the nut? how do i get the horn section off?
in my ke20 there was screws in the back of the wheel that allowed the front horn section to come off so that i could get to that nut!
[Updated on: Mon, 26 May 2003 08:01]
Ruckus
Melb
Re: Remove steer wheel on ke11? Mon, 26 May 2003 07:59 Go to previous messageGo to next message
it is an original wheel incase you didn't realise.
juzzo84
Hornsby, N.S.W
Re: Remove steer wheel on ke11? Mon, 26 May 2003 08:09 Go to previous messageGo to next message
WHACK IT, WHACK IT GOOD Very Happy
Re: Remove steer wheel on ke11? Mon, 26 May 2003 08:26 Go to previous messageGo to next message
oooohhh, thats what ya meant..
to get the horn pad off, hold it at the outer edges, maybe 1-2" from the ends and prise off with ya fingers.... do one side at a time.. it has a plastic thingy that goes over a bolt head (effectively) so you have to pull it just enough to pop off.. screwdrivers aren't good... you just need to sort of stick your fingers in and use them to expand the gap between the pad a wheel? that makes sense?
there is only 1 retaining point per side, and try not to yank one side out too much before lifting off the other side, or it can break...
i don't have one here to take a pic of Sad... sorry...
Ruckus
Melb
Re: Remove steer wheel on ke11? Mon, 26 May 2003 08:31 Go to previous message
thanks heaps, i thought it might be something like that, il try now
Previous Topic:Gear Boxes For AE86 sprinter
Next Topic:RA65 Celica - Custom sway bars / struts etc
Current Time: Mon Oct 26 15:01:08 UTC 2026
Total time taken to generate the page: 0.19916892051697 seconds
