Toymods » Tech & Conversions » extreemly simple question for ae86 sprinter guys
Widowmaker
Mexico
extreemly simple question for ae86 sprinter guys Mon, 26 May 2003 09:47 Go to next message
ok im trying to get my steering wheel off to try another but i cant get the stock one off , ive tried undoing 2 screws behind the wheel oposite where the horn buttons are but to no avail so if someone could point me in the right direction that would be great.
gabe
Re: extreemly simple question for ae86 sprinter guys Mon, 26 May 2003 10:45 Go to previous messageGo to next message
there is a nut(19mm i think)
you have to pull the 'S' Sticker off and pull a rectangular plastic plug out to get to it.
when i did mine i wound the nut off 3/4 of the way and tapped the nut with a hammer just to crack the tapered spline
often if you wind the nut off all the way and pull on the wheel you can end up smacking yourself in the face with the wheel
hope this helps
gabe
Ruckus
Melb
i was justing trying the same thing on my ke10,
now that youve undone those screws behind the horn button, try and kind of get ur fingers in between the horn and the wheel on each side and just pull with a bit of pressure.
there will prbably just be some kind of plastic one-way clip thing going on. There was on mine.
EVOSTi
cambo
      no
Re: extreemly simple question for ae86 sprinter guys Mon, 26 May 2003 11:55 Go to previous messageGo to next message
ive done it on my sprinter a few times, just get a flat head screwdriver in behind the plastic rectangle in the middle and take it out, then theres a 19mm, undo that most of the way. grab the top and bottom and yank on it like all shit and then when it comes lose take the nut the rest of the way off. theres really no other way then just really forcing it sometimes theyre a prick to get off.
king16
camden
Re: extreemly simple question for ae86 sprinter guys Tue, 27 May 2003 11:33 Go to previous messageGo to next message
if that doesnt work, you probably need a wheel puller. there bout $20 or something like that and there easy to use and you will have the wheel off in no time... Razz
Widowmaker
Mexico
Re: extreemly simple question for ae86 sprinter guys Tue, 27 May 2003 12:29 Go to previous messageGo to next message
grrrr i took off the S badge but saw the other part and didnt think it came off. anyway so i did get it off so thanks for the info but the leather wheel from a SW20 didnt quite fit though due to a small part on the new wheel so i guess its the stock wheel for a bit longer.
EVOSTi
cambo
      no
Re: extreemly simple question for ae86 sprinter guys Wed, 28 May 2003 11:37 Go to previous message
i coulda told you that Smile dont know what wheels fit from stock i think maybe cressida's? not sure.
Previous Topic:Supra Gearboxs
Next Topic:4AGZE Into Datto 1000 Ute
Current Time: Wed Oct 14 10:44:10 UTC 2026
Total time taken to generate the page: 0.027606010437012 seconds
