Toymods » Tech & Conversions » AE86 Diff centre comparisson/conversion
gtvtrueno
icon10.gif  AE86 Diff centre comparisson/conversion Mon, 24 June 2002 21:47 Go to next message
i need help, i'm lookin for replacement for my diff centre in my ae86 trueno. its too noisy now(louder than my exhaust) i have the disc axle with 4.11 final.
is there any other toyota diff centre that can fit to this axle?
and can i get 2way LSD easy for this centre?
btw my centre is the last model soo it is bigger than ae71 type.
i have lock centre but too much problem thats why i didn't use them.
thnks Rolling
._T_.
Re: AE86 Diff centre comparisson/conversion Mon, 24 June 2002 22:36 Go to previous messageGo to next message
you should have a 6.7" diff i assume, unless you have a very late update diff ('87) with the update axles - in which case you still have a 6.7" diff, but the spider gears will be a bit different.
you have several options -
buy a 4.1 out of a t18/ta22 etc.
buy my 6.7" 4.3
buy a new one from toyota
you will still have to do some retrofitting to get it going if you do have an update diff though
T
gtvtrueno
6.7" ?? Thu, 27 June 2002 06:14 Go to previous messageGo to next message
Hi T,
i'm still confuse. coz all i know there's only 2 type disc rear axle for sprinter. the early model had smoller centre and lighter like what zack got now. i think his looks the same as ae71. soo how do i check if yours is the same?? or mine is 6.7" diff. i really want the 4,3 ratio as i think the na 4ag benefit alot from it.
soo what size is the local drum end sprinter axle?? it looks the same as local ke70 or import ae71 with disc.
thnks.
Rolling
[Updated on: Thu, 27 June 2002 06:17]
chrisss
melb
Re: 6.7" ?? Thu, 27 June 2002 12:11 Go to previous messageGo to next message
Im confused too
- I thought the australian AE86 had the S series diff.
- I know the local KE70 had BorgWarner diff and the imported KE70 panel van had the S series diff (I have physically seen them).
- The AE71 sedan (local) I presume had the BorgWarner also, AE71 import (ie panel van) probably would have had a jap diff (S ot T I presume).
can anyone confirm what the AE86 had.
Ive heard the AE86 had the S series in australian models and the T series in other overseas models ( as mentioned in the "F series with LSD" thread by hiaaa)
also what ae71 are you talking about as no local one ever came with rear discs.
1bam777
Perth WA
Re: AE86 Diff centre comparisson/conversion Thu, 27 June 2002 14:08 Go to previous messageGo to next message
Hey Guys!!
Aie, the best way to find out is to pull the diff out, then measure the axles and check the number of splines on them. If you want to, bring your diff to my workshop, and we can check if yours is the same as mine. Got a couple of spare axles lying around, and probably a couple of blown diffs too. Then you can confirm with Toby regarding the diff.
Gimme a buzz.... need to sort something out.
Zacky
hotgemini
Brisbane, Queensland
Re: AE86 Diff centre comparisson/conversion Tue, 28 September 2004 21:56 Go to previous message
Apologies for bumping an old thread, I've got a friend with an Aus spec AE86 with a nicely bent axle. Will the KE70/AE71 wagon axles be likely to fit? Are there any other local plentiful sources of AE86 axles (right hand side if anyone cares)?
Previous Topic:XT130 struts into KE55..
Next Topic:ae86 air conditioning.
Current Time: Sun Oct 25 18:16:11 UTC 2026
Total time taken to generate the page: 0.0084240436553955 seconds
