Classifieds » Parts Wanted » GZE pulley 1st o/size
Sprocket
The Central Coast
GZE pulley 1st o/size Tue, 27 May 2003 02:37 Go to next message
Wanted: GZE pulley, 1st oversize.
Prefferable to run 9-11psi.
Original pulley was replaced with one that runs max of 6psi. Probably generic 4AGE pulley.
Will even consider really cheap std size pulley if people have them lying around (I know some jap front cuts came out with slightly larger pulleys)
Will measure current pulley shortly (it's a bugger to get your hands in)
Sprocket
The Central Coast
Re: GZE pulley 1st o/size Wed, 28 May 2003 02:48 Go to previous messageGo to next message
Looking for a 145mm pulley
feral4mr2
Bundaberg, Qld.
Re: GZE pulley 1st o/size Wed, 28 May 2003 12:05 Go to previous messageGo to next message
145mm is the factory size pulley for approx 8psi.
i have a 160mm one good for approx 10psi,(HKS or Blitz, cant remember which one is 160mm or 165mm)..
Sprocket
The Central Coast
Re: GZE pulley 1st o/size Thu, 29 May 2003 00:12 Go to previous messageGo to next message
I'm interested, for sure.
Well now that you say 145mm is standard, I'm still after that size anyway, because I measured it last night, and it's 135mm.
How much do you want for the 160mm one? If it's cheap enough, I might just do that instead.
feral4mr2
Bundaberg, Qld.
Re: GZE pulley 1st o/size Sat, 31 May 2003 10:17 Go to previous messageGo to next message
hows $150 plus freight grab ya?
Sprocket
The Central Coast
Re: GZE pulley 1st o/size Sun, 01 June 2003 23:34 Go to previous message
You have a PM!
Previous Topic:WANTED- ABS sensor from R154 equipped 70 series supra
Next Topic:WTD: LHS Headlights/Guard for Sprinter
Current Time: Fri Nov 20 21:35:59 UTC 2026
Total time taken to generate the page: 0.01308798789978 seconds
