Toymods » Tech & Conversions » will Springs and Dampers from a RA23 fit into my TA22??
BOGking
icon5.gif  will Springs and Dampers from a RA23 fit into my TA22?? Tue, 27 May 2003 07:27 Go to next message
As usual i didnt stop to think about weather suspension from a Ra23 will be compatible with my car.
Sooo... should i start to panic or not??
Henn
Rosanna, Melb
Re: will Springs and Dampers from a RA23 fit into my TA22?? Sun, 15 June 2003 15:49 Go to previous messageGo to next message
I haven't had experience with exactly your issue, but I've found in general, Toyota stuff fits heaps of different models.
Just pull them out and check.
Hen
BOGking
Re: will Springs and Dampers from a RA23 fit into my TA22?? Tue, 17 June 2003 09:04 Go to previous messageGo to next message
yeah i think i will have to do that.
but i think the front setup will be the wrong height. the struts of the ra23 r abit longer that the ta22s. we will see what happens.
i will giv it a go soon! thanks.
dorikin
NE Melbourne
Re: will Springs and Dampers from a RA23 fit into my TA22?? Wed, 18 June 2003 02:16 Go to previous messageGo to next message
the rears will, but the fronts wont. the front struts in the RA23 are taller...
simulant
Sydney - Northern Beaches
Re: will Springs and Dampers from a RA23 fit into my TA22?? Wed, 18 June 2003 08:27 Go to previous messageGo to next message
I got some cheap what I thought to be lowered springs out of a ta22, put them in my ra28 with no worries, but either things are sligthly different or, the springs weren't lower, cause it rides at the same height, posibly higher by about 5mm, but if the 23-28 struts are longer then I would have thought the oposite would occur, well, anyway food for thought.
Al
BOGking
Re: will Springs and Dampers from a RA23 fit into my TA22?? Fri, 20 June 2003 15:18 Go to previous messageGo to next message
thanks dorikin.
and simulant.. i have no idea on that 1 ! Laughing
but i am sure the rears will be very similar.
i will check it again just to be sure but many hav told mee it will be taller.
oo also does any1 know if KYB inserts are any good? mono tube??
or monroes gt gas will be betta?
or Peddas not GAS but the other ones for older cars(white color shocks)?
thanks.
jason.
juzzo84
Hornsby, N.S.W
Re: will Springs and Dampers from a RA23 fit into my TA22?? Fri, 20 June 2003 22:40 Go to previous message
the gt gas are ok, they are a very hard shock absorber when it comes to lowered springs you will get the shit beaten out of you running over bumps and stuff, the kyb stuff is ok, its fairly cheap and not that great!!! pedders i would not touch, i had sports ryders in my 22 and going along the freeway one of the rear shocks snaped!! VERY DANGEROUS!!! so now i just dont trust em.
justin
Previous Topic:And you guys looked down on a 4AC.. tsk tsk
Next Topic:do toyota make an alloy block engine besides the 1 UZ?
Current Time: Thu Nov 19 08:24:46 UTC 2026
Total time taken to generate the page: 0.0042250156402588 seconds
