Toymods » Tech & Conversions » is "91 2.5TT soarer LSD" compatible with "94 Turbo Supra"
irishtwincam
Ireland
is "91 2.5TT soarer LSD" compatible with "94 Turbo Supra" Tue, 27 May 2003 14:33 Go to next message
Is a
"91 2.5TT soarer LSD" compatible with "94 Turbo Supra"?
If not, what else from the toyota range fits?
thanks!
P
Re: is "91 2.5TT soarer LSD" compatible with "94 Turbo Supra" Tue, 27 May 2003 23:22 Go to previous messageGo to next message
Both cars have G series diffs, so yes they should be interchangeable.
Re: is "91 2.5TT soarer LSD" compatible with "94 Turbo Supra" Wed, 28 May 2003 00:31 Go to previous messageGo to next message
They don't have G-series do they? I thought it was something different?
Nevertheless, whatever they do have, its the same Very Happy
Re: is "91 2.5TT soarer LSD" compatible with "94 Turbo Supra" Wed, 28 May 2003 01:55 Go to previous messageGo to next message
Toyota changes their axle codes in the early 90's. I think the Soarer and Supra have an A series diff according to the build plate, but it's the same as the old G series.
E30-323ti
Re: is "91 2.5TT soarer LSD" compatible with "94 Turbo Supra" Wed, 28 May 2003 04:50 Go to previous messageGo to next message
Except the ratio will be different.
Assuming the JZA80 is Turbo it may have a V161 (6 spd) or auto.
I think they have a final drive around 3.2:1 where as a 5spd JZZ30 will have a 3.7:1.
Stenno
Re: is "91 2.5TT soarer LSD" compatible with "94 Turbo Supra" Wed, 28 May 2003 06:05 Go to previous messageGo to next message
For the supra there are 2 diff codes
A & B.
This is the ring gear size I beleive, and is the start number.
They also have an A & B at the end of the diff code which is non lsd (A) and Torsen (B).
Jeremy, are you sure they're a renamed G series?
Re: is "91 2.5TT soarer LSD" compatible with "94 Turbo Supra" Wed, 28 May 2003 08:09 Go to previous message
Um... I'm pretty sure. If not the same they would have to be similar, ie an evolution of the G series.
Previous Topic:removing 1jz wiring
Next Topic:18R-GEU wont start: Do i need to run a Fuel Pressure Regulator?
Current Time: Fri Nov 20 09:59:15 UTC 2026
Total time taken to generate the page: 0.011188983917236 seconds
