Toymods » Tech & Conversions » Will RA23 Springs and Dampers Fit into a TA22?
BOGking
Will RA23 Springs and Dampers Fit into a TA22? Tue, 27 May 2003 14:34 Go to next message
thinkin of purchasing an old set of suspensions from a RA23, for my TA22.will it be compatible?
any info or hints will be great.
thanks.
ChuckLandwehr
Re: Will RA23 Springs and Dampers Fit into a TA22? Wed, 28 May 2003 09:47 Go to previous messageGo to next message
Rear springs and shocks definitely will fit! you can use almost the entire front struts/brake/hub assembly from a 23 onto a 22, just change the strut top (the 3 bolt pattern is different 22 to 23), and bolt it in with the added advantage of Bigger brakes, but hey dont expect to fit your 13" stock rims back on!
regards Chuck
BOGking
Re: Will RA23 Springs and Dampers Fit into a TA22? Wed, 28 May 2003 10:45 Go to previous message
thanks for the info chuck!
i will try to fit them this weekend! should be fine and should only inflict minor injuries to myself. Very Happy
Previous Topic:4AGZE Into Datto 1000 Ute
Next Topic:HELP!! need stock 18R-GEU ecu Injector specs.. What can be used in upgrade??
Current Time: Wed Nov 25 23:40:23 UTC 2026
Total time taken to generate the page: 0.0050098896026611 seconds
