Toymods » Tech & Conversions » removing 1jz wiring
removing 1jz wiring Wed, 28 May 2003 06:19 Go to next message
ok, I think i know the answer, but is there a secret trick to removing the 1jz wiring?
the only option I can see at the moment is to pull off the inlet manifold... and ideally I'd like to avoid that if it's not necessary
Stenno
Re: removing 1jz wiring Wed, 28 May 2003 07:32 Go to previous messageGo to next message
when we stripped down a mates 1jz the weekend before last, we didn't bother trying to remove the harness from the intake manifold until the manifold was unbolted off the head, there may be a 'secret trick' to it, but this is how we did it.
[Updated on: Wed, 28 May 2003 07:33]
Mos
Toymods IT Secretary
Oz
Re: removing 1jz wiring Wed, 28 May 2003 07:42 Go to previous messageGo to next message
Have you removed the fuel rail?
On most toyota engines the loom will come out, albeit with some persuasion, once you remove the fuel rail.
Good luck.
Mos.
Re: removing 1jz wiring Wed, 28 May 2003 08:34 Go to previous messageGo to next message
my problem is I dont want to remove *all* of it. I just want to remove most.
I had a go at drawing some of the wires through (like the no6 injector, which is closest to the end I was pluuing from) but as I thought, they're too tightly packed/twisted to be pulled out like that
Stenno
Re: removing 1jz wiring Wed, 28 May 2003 08:50 Go to previous messageGo to next message
I guess I should have simply said that the harness looks impossible to remove without removing the intake manifold, thus we removed it whilst still attached to the manifold.
Re: removing 1jz wiring Wed, 28 May 2003 08:54 Go to previous message
that's what I thought
I've got a manifold+harness sitting on the floor of my garage, and it looked difficult, to say the least
Previous Topic:spare parts CD
Next Topic:is "91 2.5TT soarer LSD" compatible with "94 Turbo Supra"
Current Time: Fri Nov 20 10:07:14 UTC 2026
Total time taken to generate the page: 0.010138034820557 seconds
