Toymods » Tech & Conversions » 5mge crankshaft in a 7mgte
streetknight
boston mass usa
5mge crankshaft in a 7mgte Wed, 28 May 2003 06:49 Go to next message
i have been reading this for a while and wanted to see if any one has actually tried it. has any one ever tried to swap a 5mge crank and rods into a 7mgte block and pistons. to make it a more "square"engine seeing how the 7mgte has a 83x91mm stroke with the 5m crank and rods it would give it a 83x83mm stroke. just wondering if any one has tried this before to shed some light on it. thanks sam
streetknight
boston mass usa
Re: 5mge crankshaft in a 7mgte Fri, 30 May 2003 03:18 Go to previous messageGo to next message
any one???
ed_ma61
Lost in the K hole
Re: 5mge crankshaft in a 7mgte Fri, 30 May 2003 03:25 Go to previous messageGo to next message
that would just be a '5mgte'
it would just have a 24v head and oil squirters...
many many people have turboed the 5mge for various reasons (usually advantageous over the 7m due to 2v assembly). does anyone know the difference in the rod/stroke ratio between the 5m and 7m? thats where the advantages are to be had, not so much in the 'square' aspect.
[Updated on: Fri, 30 May 2003 03:51]
Re: 5mge crankshaft in a 7mgte Fri, 30 May 2003 03:51 Go to previous messageGo to next message
I can't say I have done it.
Post 84 5MGEs and the 7MGE/GTE run the same bearings.
Definitely doable but you'll need to play with the rods and pistons to get the right combo for the deck height.
Like Ed said, it's just a 5MGE with 24 valves and oil squirters. One of the attractive things about the 7M is the wads of low down torque - you'll lose some of that with the shorter stroke and drop in capacity.
ed_ma61
Lost in the K hole
Re: 5mge crankshaft in a 7mgte Fri, 30 May 2003 04:00 Go to previous message
gianttomato wrote on Fri, 30 May 2003 13:51
i actualy fiddled with a few engine parameters once on a desktop dyno... you lose the torque, and you do gain considerable revs. but with that, the power and torque bands go up... BUT strangely, despite revving more, the lower capacity and shorter stroke NEVER managed to regain the absolute torque and power figures of the original 7m setup.
pity the 7m just doesnt rev little better - hen it would be an absolute screemer... gues tht why they changed the bore and rod legth and created the 2jz...
ed
Previous Topic:Supercharged 7mge
Next Topic:Wheel alignment
Current Time: Tue Nov 10 04:21:49 UTC 2026
Total time taken to generate the page: 0.016811847686768 seconds
