Toymods » Tech & Conversions » Ke15 2tg conversion troubles (250KB of images)
gearb0x
Ke15 2tg conversion troubles (250KB of images) Thu, 29 May 2003 06:09 Go to next message
hey
ive got a KE15 with a 2TG i bought pre converted and im getting it ready for use in autocross
has anyone else done this conversion as after redoing all the steering/suspention gear i found the tie rod end on the steering is hitting a makeshift mount for the clutch cable (t50.. wasnt converted to hydralic) i might try get a photo..
But looking at the hydralic setup on my T-18 i dont think their would be any room for the slave cylinder even if it was converted..
Phill
[Updated on: Thu, 29 May 2003 08:04]
Re: Ke15 2tg conversion troubles Thu, 29 May 2003 06:47 Go to previous messageGo to next message
that could be a bit of trouble...
if you can get a photo that would help a lot.
fwiw, the hydraulic slave might be further down the bellhousing than the cable setup and so with some fancy lines you might clear the tie-rods..
if you can email me a pic at stewie@unsw.edu.au, i'll see what can be come up with...
gearb0x
Re: Ke15 2tg conversion troubles Thu, 29 May 2003 07:49 Go to previous messageGo to next message
Here are some images (sorry about size detail is allways good)
A bit dirty cause i was to lazy (stupid?) to wash before i started work... as u can see there is no rubber boot on the clutch fork i found out to my discust after thrashing through a muddy farm Sad (that stupidity element is there again)
http://www.inverse.com.au/~gearb0x/DCP_2894.jpg
http://www.inverse.com.au/~gearb0x/DCP_2895.jpg
http://www.inverse.com.au/~gearb0x/DCP_2896.jpg
http://www.inverse.com.au/~gearb0x/DCP_2897.jpg
gearb0x
Re: Ke15 2tg conversion troubles (250KB of images) Thu, 29 May 2003 11:45 Go to previous messageGo to next message
anyone?
so far it has been sugested that i move the engine back...
which is a no go because it is almost touching the firewall as it is an the class it will be racing in u cant cut the firewall to fit anything in....
other sugestion is to move the fork 50mm up, which requires a little fabricating on my part (a world first for me :/) got all the tools thats not the problem... i guess i could get a spare housing to screw around with...
any more easier ideas ? Razz
TA22-3SGTE
MACKAY
Re: Ke15 2tg conversion troubles (250KB of images) Thu, 29 May 2003 13:17 Go to previous messageGo to next message
Is it only hitting on or near full lock if so could you get away with adjusting the full lock stop to stop getting as much lock in that direction.
Trevor
Re: Ke15 2tg conversion troubles (250KB of images) Fri, 30 May 2003 01:24 Go to previous messageGo to next message
a couple of things..
from the pics it looks like you could move the makeshift mount up a bit... is the cable between the mount and the fork horizontal?, if not move it up and that will give ya a little more...
also what is space like on the passenger side of the gearbox? you could just change the engine mounts a bit to move the whole engine/gearbox across to the passenger side.... even 1cm will give you a lot more turning
anothe roption again is to tile the engine toward the passeneger side a bit more to rotate the makeshift mount higher...
hmm, so i reckon if the makeshift mount is not horizontal, make it so (or a little higher) then take off the motor mounts and unbolt the gearbox mount and shift the engine (with pulley or hoist Wink ) around a bit to try and get more space there... you should have 10 or 15mm to play with at least...
if you were in sydney i'd offer to bring it around and we could weld then mounts up then and there..... doh..
good luck,
1G-GE KE35
Welly, NZ
Re: Ke15 2tg conversion troubles (250KB of images) Fri, 30 May 2003 03:17 Go to previous messageGo to next message
I agree, try and move the bracket up. Shouldn't make to much difference, but you may need to adjust the cable to get the correct amount of travel again.
Do you have any other pics of the car?
Sam Smile
gearb0x
Re: Ke15 2tg conversion troubles (250KB of images) Fri, 30 May 2003 07:35 Go to previous messageGo to next message
ill give the nwe bracket a try..
the carbies are outa tune so i gotta work that out as well... there is still bits and pieces to do before its race worthy... i cant wait Evil or Very Mad
as for teh pictures
http://www.inverse.com.au/~gearb0x/racer1.jpg
http://www.inverse.com.au/~gearb0x/racer2.jpg
juzzo84
Hornsby, N.S.W
Re: Ke15 2tg conversion troubles (250KB of images) Sat, 31 May 2003 14:05 Go to previous messageGo to next message
looks great, good luck getting it going Smile
gearb0x
Re: Ke15 2tg conversion troubles (250KB of images) Tue, 16 September 2003 13:22 Go to previous messageGo to next message
TA22-3SGTE wrote on Thu, 29 May 2003 23:17
Trevor
Have you got any idea where this lock would be on a ke15? i cant see anthing like what you speak off
i could be wrong
Thanks,
Phill
Re: Ke15 2tg conversion troubles (250KB of images) Tue, 16 September 2003 13:50 Go to previous message
it's a funny one on a KE10.. you can actually see it in the first three pics that you put up...
in the third picture, look directly above and a little to the right of the tie rod end. see that bolt and nut??? from memory (it's a little dark to get under the car) the bolt hed stops the pitman/idler arm travel toward the centre of the car, and this is how full lock is adjusted Smile
btw, if you ever want to sell that KE15 body, let me know Very Happy
Previous Topic:7MGTE Bore x Stroke ??
Next Topic:Solid engine mounts DO IT YOURSELF
Current Time: Fri Nov 20 05:18:30 UTC 2026
Total time taken to generate the page: 0.0069630146026611 seconds
