Toymods » Tech & Conversions » sprinter fuel pump
cri_ag
northern beaches
sprinter fuel pump Thu, 29 May 2003 10:07 Go to next message
ive read the ae82 twinky fuel pump will fit the sprinter tank but you need to lenghten the bracket? i was wondering if anyone had performed this and could explain exactly what was involved and posibly some pics?!
IRA11Y
Club Member
Re: sprinter fuel pump Thu, 29 May 2003 10:22 Go to previous message
Yes it works, Im guessing you read that from my article.... you will need to add about 45mm to the bracket by either welding or riveting(not the preferred method but does work) in a steel section, the best way is to measure the depth of your tank and then your bracket and work out how much you need to add to make it sit on the bottom of the tank.
you will also have to lengthen the wires to the pump and redo the earth wire
Previous Topic:black to chrome
Next Topic:Removing dirt/mud from inside sill panel
Current Time: Fri Oct 23 04:51:31 UTC 2026
Total time taken to generate the page: 0.1297390460968 seconds
