Toymods » Tech & Conversions » Wheel alignment
Chris-008
Wheel alignment Thu, 29 May 2003 10:51 Go to next message
What is involved or adjusted.??
manipulate
Re: Wheel alignment Thu, 29 May 2003 11:30 Go to previous messageGo to next message
Camber is adjusted
Toe in is adjusted
Caster is adjusted
whats involved...
hooking the car up very carefully to a wheel alligner machine....the machine reads all the above readings to the nearest 0.1 degree....to my knowledge anyway....and u turn certain nuts accordingly
gold28
Madrid - Spain
Re: Wheel alignment Fri, 30 May 2003 03:46 Go to previous message
Camber and Caster cannot be altered on most cars, not without some modification.
Generally only toe can be adjusted. This is done by adjusting the tie rods (bits between steering box/rack and your hubs)
Just incase you are unsure what the meaning are,
Toe: look down at your feet Very Happy the toe is the relative angle between the front wheels, it pidgeon toe (toes in, heals out) is toe in and vice versa for toe out. Normally your car has 1 or 2 degrees toe in to account for drag on your wheels pulling on the suspension. Ideally you would like the wheels striaght when moving.
Chamber: look at the front of your car. The tops of the wheels should be slightly leaning towards each other. Classic examples are, Negative Chamber: rear wheels on a heavily (cheaply) lowered Datsun 1600. Positive Chamber: rear wheels on a standard swing axle VW. This can generally only be adjusted by changing strut tops or modifying the lower suspension mounting points.
Caster: This is the angle of the strut when looking at the side of your car. This effects lateral stability (steering) and response of the steering. Once again, it can only be adjusted by modifying the suspension mounting points.
Previous Topic:5mge crankshaft in a 7mgte
Next Topic:w58 gearboxs
Current Time: Sun Nov 22 22:30:16 UTC 2026
Total time taken to generate the page: 0.0050759315490723 seconds
