Toymods » Tech & Conversions » Engine Swap for KE3x Corolla
oldskoolrolla
Ashmore, QLD
icon5.gif  Engine Swap for KE3x Corolla Fri, 30 May 2003 00:16 Go to next message
Hey everyone,
I'm looking at purchasing a KE30 2-door sedan, with a 1.2L 3K-c engine Embarassed I would like to change the engine for something with more potency futher down the track, does anyone have any good ideas for engine swaps, with a budget of $1500
Any help will be appreciated.
Danniel
[Updated on: Fri, 30 May 2003 00:17]
vr4gsr
Re: Engine Swap for KE3x Corolla Fri, 30 May 2003 00:45 Go to previous messageGo to next message
Hey how's it goin?
Well probably the easiest and cheapest(but also the least powerfull)of any conversion in that car, would be putting in a 5k corolla engine( from a ke70 i think?)
Then you could consider any of the 4ag series engines from the 86kw version to the supercharged 4agze version,
depending on how much u want to spend.
Will u be doing the work on the car or will you be getting someone to fit it for u?
At the moment im considering a carby turbo conversion on the 3k in my ke30 so thats also an option for you to consider.
hope this helps anyway.
vr4gsr.
oldskoolrolla
Ashmore, QLD
Re: Engine Swap for KE3x Corolla Fri, 30 May 2003 02:33 Go to previous messageGo to next message
Hey mate,
Hows it going? What sort of turbo setup are you considering putting on your 3k engine? It would make things interesting, and is also something for me to consider. I think most of the work will be best left to the professionals in my case. I was considering a 4agze engine as an option, because I am not too keen on turbos (sorry guys Twisted Evil ) What other mods have you done to youe KE30?
rob_RA40
c'town, NSW
Re: Engine Swap for KE3x Corolla Fri, 30 May 2003 02:36 Go to previous messageGo to next message
for $1500 and no turbo try the 2T-G
oldskoolrolla
Ashmore, QLD
Re: Engine Swap for KE3x Corolla Fri, 30 May 2003 03:43 Go to previous messageGo to next message
I was considering the 2T-G, as it was the engine used in the similar models of Corollas in the US and Japan, and fabricating new mounts for it seems relatively easy (in theory), it seems to be the straightforward choice with reliability to boot, as well.
Any oother engine ideas are still welcomed, thanks Smile
EMP-2TG
Carlingford, Sydney
Re: Engine Swap for KE3x Corolla Fri, 30 May 2003 10:55 Go to previous messageGo to next message
yeah 2TG's dont go to bad
or 4age if u want to put in some more effort with not that much more gain
oldskoolrolla
Ashmore, QLD
Re: Engine Swap for KE3x Corolla Fri, 30 May 2003 14:36 Go to previous messageGo to next message
out of the two (2tg and 4-age) i would rather install the 2tg, because there is less fabrication involved, and it is more suited to the corolla's age and genre, which is important, as I want to keep with the 'old school' theme. Very Happy Smile Very Happy
Now all i have to do is buy the car Very Happy
1jmx83
Re: Engine Swap for KE3x Corolla Sun, 29 June 2003 09:36 Go to previous message
The 2t/2tg engine is the easiest swap! Ive done this conversion with a 2t into a ke30 twice. You use the celica mounts and they bolt straight up to the corolla cross member. I used the celica 5 speed with the cross member and just drilled new holes in the g/box cross member that matched up with a set of bolt holes in the chassis. I am pretty sure the tailshaft is a (ke16 or 10) wagon tailshaft with celica/corolla uni joints. The hardest part is probably changing to a hydraulic clutch but there are spare bolts in the firewall that can be used with a bit of mucking around with the pedals.
I was running extractors and two inch exhaust and it surprised quite a few people. I have since blown the engine Mad . But have now recond an engine and bought a manifold, to4 turb and weber to fit so once i get back into the shed i will have to put this package together for some fun!!! Evil or Very Mad Hope I could be of some help! if you need any more info just email me and I will try and get it for u.
Ben
Previous Topic:Help Please
Next Topic:3T-GTE head gasket
Current Time: Fri Nov 20 23:11:38 UTC 2026
Total time taken to generate the page: 0.0059921741485596 seconds
