Toymods » Tech & Conversions » thermo fan wiring
Mr DOHC
thermo fan wiring Sat, 31 May 2003 03:51 Go to next message
i plan to hook up a thermo fan to my corona this weekend, the fan is 10 inch wide would this been suitable for an 18RGU, or would i need bigger
is this how the wiring goes for the relay
85= constant positive
86= ground
87= output to fan
30= accessories
Re: thermo fan wiring Sat, 31 May 2003 05:42 Go to previous messageGo to next message
depends,, 10 may be enough, 12 may be better. give the 10 a go.
philmelvin wrote on Sat, 31 May 2003 13:51
86= ground
87= output to fan
30= accessories
umm, well the relay coil is across 85/86.
if you have a switch with power and you are grounding thru the relay, then the switched power and ground go across 85/86. if you are using a toyota temp switch, the put fused power (like accessory) to one of 85/86 and the other to the temp switch (which grounds to the engine block).
for the fan, it depens if you run power to fan or the fan is grounded?
if power goes to fan first, then put fused power from battery to the fan, then from fan go to 30. then 87 goes to ground.
OR you could run fused power to 30, then run 87 to fan and then ground the other fan wire....
basically 85/86 is the low current side that switches the relay, and 30/87 is the high current switched side, that you put the fan on....
hope this helps..
BansheeBuzz
Gold Coast
Re: thermo fan wiring Sat, 31 May 2003 21:19 Go to previous message
I take it you want the fans to come on with ignition?
If so
30 - Fused battery supply
87 - To Fan
85 - Earth
86 - ignition.
You are better off putting a thermostat on there to control the fan as it does not need to run all the time.
Previous Topic:Rear Windscreen demister terminal?
Next Topic:What does a 1.8 3TGTEU come out of?
Current Time: Thu Nov 19 03:46:58 UTC 2026
Total time taken to generate the page: 0.0054121017456055 seconds
