Classifieds » Parts Wanted » wanted: 1JZ Dump pipes
jzz30
wanted: 1JZ Dump pipes Sat, 31 May 2003 04:30 Go to next message
new or second hand
jim@jbperipherals.com.au
1JZ.747
Osama's hideout
Re: wanted: 1JZ Dump pipes Sat, 21 June 2003 06:44 Go to previous messageGo to next message
mine wont fit your car bro,
but my exhaust guy makes several sets and sends world wide , currently he has 35 guys in the states using them
Premier Exhaust
Brendon forrest
02 49 603911
tell him shane give you the number, he is a mate of mine.
my pipes gave me a 25 rear wheel kilowatt increase
and my torque went from 737 newton metres to 1116 newton meters.
email me at crichtos@anz.com
if you want anything else from me
all the best
shane. Smile
celicamad
newcastle
Re: wanted: 1JZ Dump pipes Tue, 24 June 2003 13:35 Go to previous messageGo to next message
Shane thats tractive effort not torque .your torque is more like 385nm stock .
a 2j making 874 rwhp makes about 1066 nm of torque
1100 nm of torque would be around 950 h.p
The twin pipes alone are not the answer .To get the full result .you need to use twin 3 inch cats an x pipe and prefferably 3.5 inch final pipe
Any Good exhaust shop can make them .
http://home.kooee.com.au/celicamad/Picture_0045.jpg
i originaly designed them and Joey had them made on the Central coast.The designed has Evolved Several times since then
i originally had brendon make my first ( and his) set .But have since had them modfified with excellent results
Peter from Newcastle Exhaust has done the best job IVE ever seen
and mid range torque was greatly improved .
By reversing the bends from the pic above the front turbo pipe (on left)now goes almost straight down AWAY from the Engine and the rear turbo.bends outwards and down .
ALSO If you can go slightly larger than the pipe in the picture and eliminate the bottom bend (not needed).
If you do get Brendons i recommend having them Interanlly ground with a die grinder .removing the UN-even welds and reversing the bends gave me about 10 kw more and dropped 0-100 times by 0.3 sec
1JZ.747
Osama's hideout
Re: wanted: 1JZ Dump pipes Wed, 25 June 2003 02:56 Go to previous messageGo to next message
well , like a wise man once told me
"opinions are like arse holes, every one has one"
i had my first exhaust done by the shop you are refering to, i will keep my opinion to myself about that. Cool Cool Cool
celicamad
newcastle
Re: wanted: 1JZ Dump pipes Wed, 25 June 2003 13:55 Go to previous message
Shane your opinion is well noted along with the resultant performance of your exhaust system
i believe that Both my car an Andrews both chopped you badly at dubbo .using the new design
An i believe you ran 13.3 at Eastern Creek on FULL SLICKS
not your predicted 12.5
Twisted Evil Twisted Evil Very Happy (just stirring!!!!!)
i WILL be attending the next eastern creek meet .An im happy to prove the worth of my system
Aparently someone decided that My previous post was in someway BAGGING Brendons work and contacted him . perhaps they should learn how to read
boy someone is dumb!!! did i say dont buy Brendons.....NO
anyone that has read a number of my post knows when im bagging someone i usually do it in a subtle way Rolling Eyes
like......" they are shit and dont work" ...or "overpriced garbage"
If i had a problem with Brendon hed know it .he offered to fix any problems i have ... i dont have any
I spoke to brendon today and invited him to read the post .In fact i offfered to print it out and bring it down to him
Brendon did MY exhaust .and my original twin pipes .
The quality of work was very good .however as i have already suggested spending the extra $$ to get the pipes internally smoothed is worth it .i told Brendon this today and he agreed . Brendon can do this
i also belive that ceramic coating is worth the money too but its not cheap
if your consdiering buying Brendons pipes do it .But get the whole exhaust done using the dumps then an x pipe then twin 3 inch pipes and twin cats to the diff then 3.5 after that or stick with twin or whatever fits
Brendons phone number appeared on my webpage for 6 months.after the job was done .how do you think the blokes in the U.S found out about him
I did not bag Brendon or his work .But i do belive that the newer design is better .In fact ive proven it.
Brendon will be shown the design and MAY choose to make it as well
The final exhaust system on my car has been modified by rx engineerng and lillford exhaust .
Ive tried 4 different muffler combinations .with highest power being achieved using a VERY LOUD JUN BL this was dropped for an oval muffler and a straight through glass packed steel muffler from Lillford .the end result is quiet but very high flowing .Not as much power as jun bl but my wife is happier with the new setup (after all its her car)
after all it did run 8.82 1/8th mile at dubbo with TWO mufflers .one oval, one HUGE round steel rear one .and twin fully intact cats ....hmmmmmm obviously doesnt work Twisted Evil
i Believe the work i had done by Brendon showed a good value job .The system can definatley be done better .This is not an indication of Brendons work.but that different designs give different results(i asked for 3 inch mandrel bent )The 3.5 works better .That's it
The MAJORITY of my system that still remains was built by Brendon .But final changes made to the system gave better results .I picked the original design and Lillford changed it ....why he lives 1 klm form where i live .and i wanted to try one of his mufflers ..It worked
Newcastle exhaust did a beautiful job on matts Supra and my latest design was built out of state .they work but the workmanship could be better
I made changes to the design to see what happens .several changes lost power .the final showed a BIG gain .Just a little R and d .ummmm thats how i came up with the twin pipes in the first place
as i said before ANY GOOD EXHAUST SHOP CAN BUILD DUMP PIPES.
Bloody hell its not rocket science they are only dump pipes
There are several versions floating around .the thing is without the rest of the system flowing well .dump pipes wont work
seperate wastegate pipes where tried with a slight power loss .Compared to Brendons
reversing the pipes from the pic above .therfore running the front turbo pipe( on right) almost straight down and removing a bottom bend .gave best results
to the person that obviously rang Brendon to stir shit
your stunt backfired the only persons PISSED OFF by it all was Brendon .But Instead of causing trouble Brendon i actually sorted out a seperate issue....SO THANKS !!!!
next time if you have a problem with my post .first clarify the point then if you have a problem post it or email me or ring me .
Or at least get it right if you do .
INSTEAD OF WHISPERING BEHIND THE TOILETS LIKE A SISSY
the reason i say what a believe is becuase i can back it up .both on the track or dyno .and anywhere else you think you can cut it
If you dont like my opinion ...heheheeee bad luck im used to having other people opinions in my rear view mirror,or on the canvas .happy to prove it any time Smile
Previous Topic:Wanted MS112 Diff - Sydney - Dead or Alive!
Next Topic:Autometre Tacho
Current Time: Wed Oct 21 07:03:45 UTC 2026
Total time taken to generate the page: 0.0047481060028076 seconds
