Toymods » Tech & Conversions » Post fuel-cut ECU maps question
RiGo
Post fuel-cut ECU maps question Sat, 31 May 2003 06:11 Go to next message
To all you knowledgeable ones...
What exactly happens to fuel map when you run boost higher than fuel cut (eg using a fuel cut defender).
My understanding is that the ECU opens up the injectors and dumps a whole bunch of fuel in. If that is not the case, then what does the ECU do?
If that is the case, then how can an interceptor/piggyback computer be used to tune the fuel curve past fuel cut?
Thank you!
[Updated on: Sat, 31 May 2003 06:12]
SUPRAGTE
North Sydney
Re: Post fuel-cut ECU maps question Sun, 01 June 2003 01:14 Go to previous message
Say your airflow meter is a 5volt output type. Boost cut is at 4.2volts which is 100% duty cycle of the injectors.
(0 Volts is 0% duty cycle)
At the factory they deliberatly put a safety margin in. For example, stock toyota(and all manufacturers) run really rich air:fuel ratios on full boost like 10.5 or 11:1. The 1JZ is famous for it.
This is too rich too make good power but it is safe to prevent detonation and lean out so engine's arn't damaged by morons.
Now with the injectors already at 100% and you go past boost cut with your FCD no more extra fuel can be added but this is ok up until a point. That point for turbo cars is around 12.5:1 air fuel ratio for turbos, any leaner and detonation and high exhaust gas temps becomes more likely.
FCD's are a good thing because they will allow you to run more air(boost) into the engine before it cuts out which brings up the air fuel ratio to a more power productive level.
On the LS1 holden engine they run a/f ratios to 10.5:1 which is ludicrously rich! By simply pluging in an aftermarket air flow meter with a skewed output voltage a/f ratios are instantly lifted to 12.5:1 and 20Kw gain is instantly seen at the wheels!
Previous Topic:ma61 diff replacement
Next Topic:info plz
Current Time: Thu Nov 19 05:43:54 UTC 2026
Total time taken to generate the page: 0.0047430992126465 seconds
