Toymods » Tech & Conversions » SA63 front brake upgrade?
bozwon
nowra
SA63 front brake upgrade? Sun, 01 June 2003 05:32 Go to next message
the brakes on the car are pretty good as is (except the front right disk needs changing) but would it be a good idea to change them when i put the 1g in.
legally i wont need to change the brakes when the new engine goes in as it is the same capacity as the current engine.
is there any better brakes that will bolt in with very little or no modification.
mat
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: SA63 front brake upgrade? Mon, 02 June 2003 12:37 Go to previous messageGo to next message
Nope. Considering the fronts are pretty much the same as the MA61 Supra, I don't think you really need to worry about them.
Re: SA63 front brake upgrade? Mon, 02 June 2003 23:47 Go to previous messageGo to next message
http://members.austarmetro.com.au/~mrshin/brakes1. jpg
http://members.austarmetro.com.au/~mrshin/brakes2. jpg
http://members.austarmetro.com.au/~mrshin/brakes3. jpg
Do a search, pretty sure I've mentioned the parts involved before
bozwon
nowra
Re: SA63 front brake upgrade? Tue, 03 June 2003 00:21 Go to previous messageGo to next message
acording to DBA the rotors are identicle for the ra60/65 sa63 and ma61.
i was just wondering if there was a 4 spot caliper avalible.
ill just get new drilled rotors to help disperse heat and get new pads
mat
Nark
Cabramatta, NSW
Re: SA63 front brake upgrade? Tue, 03 June 2003 01:42 Go to previous messageGo to next message
Rotors are the same. The calipers are slightly different from what I remember. I know the pads are different...
Re: SA63 front brake upgrade? Tue, 03 June 2003 03:56 Go to previous messageGo to next message
Drilled rotors don't help dissipate heat. Get slotted rotors; drilled are strictly for wank value if you don't have a full-on race car.
Nark
Cabramatta, NSW
icon1.gif  Re: SA63 front brake upgrade? Tue, 03 June 2003 04:04 Go to previous messageGo to next message
There is actually no difference in braking performance between drilled and slotted rotors.
But drilled rotors crack/warp easier.
Re: SA63 front brake upgrade? Tue, 03 June 2003 04:26 Go to previous message
Some people will argue that the slots actually make performance worse in one outright stop. That said, if you ever needed to do it over and over again, I'd go slots every time.
Previous Topic:Air Flow Meter
Next Topic:Wanna get a 20v in the sprinter......
Current Time: Thu Oct 22 16:51:03 UTC 2026
Total time taken to generate the page: 0.066857099533081 seconds
