Toymods » Tech & Conversions » removing the 1jz inlet manifold
removing the 1jz inlet manifold Sun, 01 June 2003 08:50 Go to next message
ok, pulling the wiring out with the manifold on has hit a couple of snags, so I'm going to pull the inlet manifold.
How would I do this?
First. disconnect fuel pump, and run the engine till it stalls from fuel starvation.
then disconnect any hoses that will prevent moving it.
then remove manifold and go to town.
am I missing anything? I assume I will need a new manifold gasket, but I'm more interested in problems that might cause my engine bay to catch on fire, or my engine to die Smile
Re: removing the 1jz inlet manifold Sun, 01 June 2003 12:32 Go to previous messageGo to next message
Yeah, killing the pump and running it till it dies is a good idea - but in normal EFI systems the moderate pressure (~30psi) isn't exactly gonna blast you to the moon anyway. Before you start loosen the fuel cap, and even if you don't disconnect the pump, you should only spill a small amount of fuel anyways. Another suggestion - when you've got the hoses off, shove something clean up there to stop them siphoning fuel everywhere while you're not looking Very Happy
Re: removing the 1jz inlet manifold Sun, 01 June 2003 12:46 Go to previous messageGo to next message
ehehehe
yeps, I'd thought of that.
no oil/coolant/other misc fluids to worry about?
should I clean anyhting while it's off? it's not something I want to do particularly often Smile
Re: removing the 1jz inlet manifold Mon, 02 June 2003 09:26 Go to previous messageGo to next message
also, does anyone have for sale or know where I can buy a 1jz inlet manifold gasket from? (apart from japan)
do any oz-delivered cars have the 1jz-ge, and is this manifold the same?
Soarer
Wollongong
Re: removing the 1jz inlet manifold Mon, 02 June 2003 11:04 Go to previous message
Talk to Mark Emerson at Penrith Toyota. He'll sort you out. They stock or can source 1JZ parts at reasonable prices.
Previous Topic:Wearing in new Metal Head Gaskets?
Next Topic:1GGTE or Supercharge 18RGEU
Current Time: Tue Oct 20 12:05:06 UTC 2026
Total time taken to generate the page: 0.0054099559783936 seconds
