Toymods » Tech & Conversions » 4age aftermarket cams
king16
camden
4age aftermarket cams Sun, 01 June 2003 11:35 Go to next message
hi all, does anyone know where i could get aftermarket cams from and how much they cost....? thanx guys
Re: 4age aftermarket cams Sun, 01 June 2003 12:22 Go to previous messageGo to next message
Try talking to Wade camshafts - I've talked to them a few times and they're generally pretty helpful, and reasonably priced too.
Youngy
Eskilstuna, Sweden
Re: 4age aftermarket cams Sun, 01 June 2003 12:39 Go to previous messageGo to next message
Talk to Zacka from here:
http://www.cypherindustries.com.au/front.htm
They also have Toda parts - at around 600-750 per cam depending on grind.
Enjoy
AZA510
Central Coast, NSW
Re: 4age aftermarket cams Mon, 02 June 2003 02:27 Go to previous messageGo to next message
I have a setup of cams that are for a 4AGE. they are 248@0.050" and 0.304" lift which according to 'engine anlyser pro 2' they should be around 304 degree duration. (42 - 82 cam)
Make me an offer and I may sell them.
SecaSX
Re: 4age aftermarket cams Mon, 02 June 2003 04:19 Go to previous messageGo to next message
AZA510
With the cams you have will it require an aftermarket ECU for tuning? Currently have a stock AE92 Seca SX and looking to upgrade the cams. Let me know what ur looking to get for the cams. Have the cams been used and how much gain have u got from the new cam setup.
AZA510
Central Coast, NSW
Re: 4age aftermarket cams Wed, 04 June 2003 05:10 Go to previous messageGo to next message
they have been used and yes they will make a great deal of differance to your car if you put themin right.
my friend has the same sized cams as me in his GZE running with a factory computer. Its a pain down low in the revs but we just have to sort out a better fuel map.
king16
camden
Re: 4age aftermarket cams Thu, 05 June 2003 07:32 Go to previous messageGo to next message
AZA510 how much are you looking at for the cams,will they suit 86kw 4age with stock ecu? how much power increase do they give?
cheers matey
TODA AU
Re: 4age aftermarket cams Sun, 08 June 2003 14:01 Go to previous messageGo to next message
King16,
For what it's worth, if you're going to keep the standard ECU.
The following TODA camshafts will suit your application.
264deg intake - 7.9mm lift
256deg exhaust - 7.9mm lift
For best results, you should consider a pair of vernier adjustable cam pulleys also.
Using these parts, you can realistically expect to gain 7 to 10 hp at the wheels.
kirkosaurus
Middle Tennessee
Re: 4age aftermarket cams Sun, 08 June 2003 19:37 Go to previous messageGo to next message
I'm using WebCam camshafts #294 from Cyberspace Automotive, http://www.cyberauto.com/index.php/vehicles.htm .
$400 for the pair.
king16
camden
Re: 4age aftermarket cams Mon, 09 June 2003 03:18 Go to previous messageGo to next message
kirkosaurus- are you using the standard computer?how much more power do the give?cheers dude...
kirkosaurus
Middle Tennessee
Re: 4age aftermarket cams Mon, 09 June 2003 04:40 Go to previous messageGo to next message
Yes, standard ECU. I did upgrade to 250cc injectors though. Good mid-high end power.
ae86drift
sydney.au
Re: 4age aftermarket cams Mon, 09 June 2003 05:52 Go to previous messageGo to next message
toda parts are generally awesome quality but fairly exxy
as someone has already said, youll need some camgears too
especially if you get above 290deg cams
ae86trueno
Re: 4age aftermarket cams Mon, 09 June 2003 06:17 Go to previous messageGo to next message
FWIW the WEB grind #294 has a full duration of 244 Degrees and lift is 8.2 mm, so they are only a relatevily mild cam and will defineately work with factory ecu.
Ben
AE86 Trueno 4AGE
SecaSX
Re: 4age aftermarket cams Mon, 09 June 2003 06:35 Go to previous messageGo to next message
For all these aftermarket cams do you actually loose power down low and gain power up high? Are there cams which give u power gains throughout the entire power band. Sure high end power is good for traffic light wars but if u want to be a little quicker through traffic and corners wouldn't it be better to get cams which improve lower to mid range power?
Do such cams exist??
ae86trueno
Re: 4age aftermarket cams Mon, 09 June 2003 06:50 Go to previous messageGo to next message
Sure they exist, if you want power through out the rev range probably go for probably 288 deg intake cam and 272 deg exhaust cam will give you a wider power band. But you still sacrafice a little bottom end and some top end so you have to do some research as to what power band you want.
Ben
AE86 Trueno 4AGE
AZA510
Central Coast, NSW
Re: 4age aftermarket cams Tue, 10 June 2003 01:36 Go to previous messageGo to next message
Wow those cams are small you might as well not both.. or just get early model bigport cams (MR2 NA) which have 240 degree cams. 0.295" lift.
I would like to fit them if I was going to sell them but if you really want them they are $400 I would part with them for..
see if you put different cams in you MUST check your shim to cam clearances and get new shim. I can get hold of A/M shims for cost price (still expensive). I can dial them in for the person that wants them.
As for the stock computer it can be done you dont need a after market computer. though the MAP sensor may not like it cause cams give you low manifold pressure. Though it should still work just as well.. to break the rumours you CAN have low end and mid range with cams. I had all the power I needed at 3000 ish RPM and 170hp @ 8000RPM max. with these cams in. This was in a stock 100kw motor.
If you are interested in buying them I can put them in for you and dial them up for the cost of the shim. (IF NEEDED) (I bought 14 shims for about $80 a month ago)
king16
camden
Re: 4age aftermarket cams Tue, 10 June 2003 10:21 Go to previous message
aza510-dude im really interested in the cams and sure i will buy them but my motor is being rebuilt at the moment so i dont need them just yet...is that 170hp at the wheels?what car is it?what other mods have been done? thanks dude...
give me a call if you need 2 as im very interested but theres 1 problem!im here in camden and your there in brisbane but im sure we can work something out!
cheers....
Previous Topic:1jz into ra60?
Next Topic:4agZe Cams Specs
Current Time: Tue Nov 17 15:47:33 UTC 2026
Total time taken to generate the page: 0.0086009502410889 seconds
