Toymods » Tech & Conversions » Rear Disk Brake Conversion - Hilux
sillyca
Jimboomba, Qld
Rear Disk Brake Conversion - Hilux Sun, 01 June 2003 12:25 Go to next message
I am wondering if you guys could shed some information on which toyota i would find rear disk with a hand brake cable which pulls in to the centre - i have looked the supra in the RA60 shape but this is a bit small
i want to run disks on the back of a hilux - i am also thinking of a full float rear end
so really i need the largest disk with internal drum hand brake from factory
or does any australian spec toyota have a hand brake built into the disk caliper - the us MKI supra did ours dont (run drum inside the disk)
thanks in advance
buddy
[Updated on: Sun, 01 June 2003 12:28]
Re: Rear Disk Brake Conversion - Hilux Sun, 01 June 2003 20:43 Go to previous messageGo to next message
http://www4.tpgi.com.au/users/loats/technical/mx23 /hiluxdiff.html
Re: Rear Disk Brake Conversion - Hilux Mon, 02 June 2003 00:04 Go to previous messageGo to next message
You can vastly simplify that by using an integral handbrake caliper (like off an XF Falcon or a Sigma). That would negate the whole internal drum handbrake thing.
sillyca
Jimboomba, Qld
Re: Rear Disk Brake Conversion - Hilux Sun, 15 June 2003 06:13 Go to previous messageGo to next message
gianttomato wrote on Mon, 02 June 2003 10:04
Yes but these are known to hold well
i was also hoping toyota would have one
but i am going to be building a full float toyota hilux rear axle and going to be using a landcruiser style tailshaft mounted handbrake
Sam
Sydney, Australia
Re: Rear Disk Brake Conversion - Hilux Sun, 15 June 2003 09:36 Go to previous messageGo to next message
sillyca wrote on Sun, 01 June 2003 22:25
thanks in advance
buddy
I believe the some Coronas (eg Avante ST141) have rear disks with internal drums for the handbrake.
sam
Re: Rear Disk Brake Conversion - Hilux Sun, 15 June 2003 09:53 Go to previous messageGo to next message
Biggest Toyota disk with an internal drum handbrake is the ST205 GT4 Celica. The internal drum handbrake is 170 mm and the rotor diameter is 315 mm.
Many late Toyotas have 190 mm internal drum handbrakes, (MA70, MZ20, MX83, JZA80, xZ30 Soarer), and this coincidentally is the same as VT Commodores and Tickford Fords. The HSV stuff runs out to 345 mm (I think), and if you want you could go to a Harrop rear disc with custom cast bell to 375 mm. Expect a big bill if ordering anything in that league.
Mercedes also use internal drum handbrakes with a diameter of 165 mm. Their 500SL uses a 300 mm rear rotor.
As you can see from the article, I just used the MZ20 backing plates and had them slightly modified to fit. The internal drum handbrake mechanism fits perfectly. Not at all sure how that would work with a full floating rear end.
If you plan to use a tailshaft hadbrake, then you need not worry about the internal drum handbrake at all. Use whatever rotor you want and just make an adapter plate suit.
BansheeBuzz
Gold Coast
Re: Rear Disk Brake Conversion - Hilux Sun, 15 June 2003 10:58 Go to previous messageGo to next message
putting discs on the rear of your hilux will totally upset your brake bias.
Doing this mod without modifing the front brakes will make your hilux braking worse.
Due to the fact that its a utility with a light rear and also a load proportioning valve for the rear brakes your better off leaving the brakes alone. They work very well(providing they are in good condition) as they are designed to pull your vehicle up loaded and a fully loaded hilux can easily clear 2 tonne
Re: Rear Disk Brake Conversion - Hilux Sun, 15 June 2003 11:56 Go to previous message
I use an adjustable proportioning valve, and my Hilux rear end is in a car.
Previous Topic:1ggte wiring looms
Next Topic:'77 LT*2000*
Current Time: Mon Nov 23 22:13:04 UTC 2026
Total time taken to generate the page: 0.0044429302215576 seconds
