Toymods » Tech & Conversions » 1JZ-GTE help
E30-323ti
icon10.gif  1JZ-GTE help Tue, 25 June 2002 21:00 Go to next message
Hi all,
You may wonder why a BMW owner is posting on a Toyota forum??
I think the subject may give it away.
Any how, Does anyone have a 1JZ-GTE engine manual??
If so, or if anyone else knows, I need the tightening torque for the flywheel bolts, crank pulley, cam pulleys, etc...
Thanks in advance.
Glenn
1jz-gte powered BMW 323i
Grant
Newcastle, NSW, Australia
Re: 1JZ-GTE help Tue, 25 June 2002 22:00 Go to previous messageGo to next message
I'll have a look over the next few day an get back to you. Manual is in Japanese so It'll take time to look for the appropriate pictures.
Grant
E30-323ti
Re: 1JZ-GTE help Tue, 25 June 2002 23:10 Go to previous messageGo to next message
Thanks.
Can you also tell me what wire from the ecu is for the Tacho.
JZZ30 Soarer ECU.
wastegate
Gold Coast
Re: 1JZ-GTE help Wed, 26 June 2002 03:22 Go to previous messageGo to next message
Here you go. Only cost of the image is to see some pictures of your cool conversion!
http://www.dcimports.com.au/images/Site/ecupinouts.jpg
E30-323ti
Re: 1JZ-GTE help Wed, 26 June 2002 04:40 Go to previous messageGo to next message
Thanks for that Wastegate. Most useful.
I've been taking photos through out the conversion.
Working on brakes, driveshaft, fuel system & electrics at the mo.
When its done i'll be able to put a web page together so you all can have a look.
Glenn
Pete
gold coast
Re: 1JZ-GTE help Wed, 26 June 2002 12:20 Go to previous messageGo to next message
Crank-Crank pulley = 329 ft lb (This is not a misprint, these buggers are FT)
Cam shaft-Cam pulley = 59 ft lb
Crank-Flywheel = 36 ft lb + 90 degrees
Need More??? I have them all
BTW: Glenn, that gearbox you have is a W58 from a NA 1J. the easy way to tell a W58 from a R154 is the reverse light switch is on the left hand side on a W58.
E30-323ti
Re: 1JZ-GTE help Wed, 26 June 2002 21:01 Go to previous messageGo to next message
Thanks Pete. Could you scan in the document you have with the torque figures on it. Also do you know the sequence for undoing & doing up the head, and the torque figures.
Thats interesting about the gearbox.
Does any body know the ratios for a W58??
E30-323ti
Re: 1JZ-GTE help Wed, 26 June 2002 23:15 Go to previous message
Don't worry about the ratios, I found them.
Previous Topic:Headers and turbos
Next Topic:Attn: bluewire.
Current Time: Thu Oct 15 07:03:10 UTC 2026
Total time taken to generate the page: 0.020721912384033 seconds
