Classifieds » Parts Wanted » ignition that will work with 4AG carby setup
AZA510
Central Coast, NSW
ignition that will work with 4AG carby setup Mon, 02 June 2003 02:15 Go to next message
Im after a 2T carby distributor or something that will work the ignition on a 4AG carby setup. Can anyone help?
Grega
melbourne.victoria.austra...
Re: ignition that will work with 4AG carby setup Mon, 02 June 2003 06:59 Go to previous messageGo to next message
aaron, not sure here, but, have a look at a 4AC dizzy...
Re: ignition that will work with 4AG carby setup Mon, 02 June 2003 10:08 Go to previous messageGo to next message
You have several choices here:
1. use the stock dizzy and some electronics to manage the advance
2. attack another dizzy and to make it fit
3. get something custom made Evil or Very Mad
IRA11Y
Club Member
Re: ignition that will work with 4AG carby setup Mon, 02 June 2003 10:39 Go to previous messageGo to next message
one thing that may work is an aftermarket electronic iginition kit on the factory dizzy??? there are some fairly cheap basic systems out there that you can build and some will allow slight tuning as well
Grega
Re: ignition that will work with 4AG carby setup Mon, 02 June 2003 19:49 Go to previous messageGo to next message
yeah there looks to be a jaycar couple of devices which allow you to do this...
damn haltech why did they have to stop the ig5...anyone know if msd or someone make something similar?
[Updated on: Mon, 02 June 2003 19:49]
Re: ignition that will work with 4AG carby setup Mon, 02 June 2003 23:35 Go to previous messageGo to next message
Yes, damn them and their culling of the IG5 (Mine's working just fine for now, thank you! hah) Very Happy
I think MSD have/did have a screwdriver adjustable thing, you be the judge on how well it works... Also there is the jaycar kit, which would require attacking the innards of the standard dizzy slightly (rather than having 24 teeth, you'd want 1 for every firing pulse i.e. 4 teeth), which would be fairly easy to piece together, and at that price almost worth trying for the sake of experimentation!
Grega
Re: ignition that will work with 4AG carby setup Tue, 03 June 2003 06:21 Go to previous messageGo to next message
michael, the innards of the 4AGE dizzy have the 4 tooth and the 24 tooth, so, you could prolly run it off the 4 tooth thingo already in there.
almost trying for the sake of experimentation....could be...
AZA510
Central Coast, NSW
Re: ignition that will work with 4AG carby setup Wed, 04 June 2003 05:10 Go to previous messageGo to next message
I have my solution after looking around.
use the early model distributor off the 4AGE 86KW with the 4 star wheel in the top. If you look carefully at a 4A-C distributor it has a little silver casing attached to the side just next to the dizzy cap. take off the silver cover and there is a module.
Items:
1 4A-C module
1 4A-GE 86KW dizzy
1 Coil (even 100KW coil)
I will have more on the installation when I install the module. it has 4 connectors and Im not sure which ones go where.
(2 for pickup and 2 for coil)
Grega
Re: ignition that will work with 4AG carby setup Wed, 04 June 2003 23:07 Go to previous messageGo to next message
there is actually a bosch module which does the same.
on this proviso though, you will have no vaccuum advance dude.
have a read of this from phil bradshaw : http://home.clear.net.nz/pages/phil.bradshaw/modif ications.htm#Ignition Systems
(bill sherwood did this)
AZA510
Central Coast, NSW
Re: ignition that will work with 4AG carby setup Tue, 10 June 2003 01:14 Go to previous message
Bill sherwood never ran vac advance. I know this for a fact. (friend of mine)
I dont need vac advance.
Previous Topic:WTB: MA70 SUPRA INSTRUMENT CLUSTER
Next Topic:Wanted: JZX81 engine mounts
Current Time: Fri Oct 30 17:11:04 UTC 2026
Total time taken to generate the page: 0.099119901657104 seconds
