Toymods » Tech & Conversions » W58 Gear ratio converter on speedo output? Why?
SUPRAGTE
North Sydney
W58 Gear ratio converter on speedo output? Why? Wed, 26 June 2002 05:56 Go to next message
My mate just bought a W58 the manual 5 speed from an ma61 and it has a gear ratio converter actually attached to the gearbox, its only small.
Mine is manual, why doesn't mine have it? Both boxes came from cars that were originally manual.
Anyone have any ideas, or is it just for different diff ratios?
Re: W58 Gear ratio converter on speedo output? Why? Wed, 26 June 2002 08:06 Go to previous messageGo to next message
Sounds like your mate bought a gearbox that was put in a car with different diff ratio and/or wheel size (ie non-original box), so the converter was necessary to bring the speedo back into line.
My speedo reads about 10% fast because of this - I'm pretty sure my W58 originally came out of an MA70 Supra with a much taller diff ratio. It's definitely not the original box as the car was originally auto.
Les
Re: W58 Gear ratio converter on speedo output? Why? Thu, 27 June 2002 07:21 Go to previous messageGo to next message
what does the converter look like... I actually need to get one of those to convert my speedo to the right speeds !!
Smile
Re: W58 Gear ratio converter on speedo output? Why? Thu, 27 June 2002 07:57 Go to previous messageGo to next message
The correct method to do this is to replace the little nylon gear inside the box which drives the speedo cable. You can get all different sizes to suit different diff/wheel combinations. Pull your gear out, count the teeth and from that you can determine which one you need to make your speedo faster or slower.
[Updated on: Thu, 27 June 2002 07:58]
Les
Re: W58 Gear ratio converter on speedo output? Why? Thu, 27 June 2002 23:19 Go to previous messageGo to next message
Hello !?!?
where do i buy the white bits with the teeth from ?!? Grin
SUPRAGTE
North Sydney
Re: W58 Gear ratio converter on speedo output? Why? Fri, 28 June 2002 09:21 Go to previous messageGo to next message
The ratio converter i saw on my mates gearbox, its about 3 inches long with a dog leg bend in it. It screws into the gearbox where the speedo goes in and the cable goes into the other end of it.
He says they exist on all the gearboxes both man and auto,
Re: W58 Gear ratio converter on speedo output? Why? Fri, 28 June 2002 11:27 Go to previous message
SUPRAGTE wrote on Fri, 28 June 2002 7:21 PM
I've never seen one, and I've been under quite a few Supras! The speedo cable screws directly into the box in both of my MA61's (one manual and one auto).
Previous Topic:Supra Steering Noise
Next Topic:AE92 Lower Control Arm Bush replacement
Current Time: Thu Nov 19 14:56:28 UTC 2026
Total time taken to generate the page: 0.0053520202636719 seconds
