Toymods » Tech & Conversions » 2TGEU in TA22: Do i need a surg tank?
bjkingwill
2TGEU in TA22: Do i need a surg tank? Tue, 03 June 2003 04:48 Go to next message
Hey guy just wanted to know what other people have found from having a 2tgeu in there TA22. It's standard with EFI.
If people have needed surg tank what size have they used and what sort of pumps?
I do have a VL pump, will this do the job?
[Updated on: Tue, 03 June 2003 04:49]
Re: 2TGEU in TA22: Do i need a surg tank? Tue, 03 June 2003 06:36 Go to previous messageGo to next message
the VL pump will do the job... and probably a 2-3L surge tank will be fine.
Talk to Pumpkin on the forums as he has a 2T-GEU in his TA23 and is using the same pump.
Grant
Newcastle, NSW, Australia
Re: 2TGEU in TA22: Do i need a surg tank? Tue, 03 June 2003 22:11 Go to previous messageGo to next message
Always use a surge tank. EFI pumps are not designed to suck directly from a tank. I use about a 1 litre surge tank and could send you a pic of a set-up in a TA23 if you're interested. Send me an email about it.
[Updated on: Tue, 03 June 2003 22:11]
Re: 2TGEU in TA22: Do i need a surg tank? Wed, 04 June 2003 00:40 Go to previous messageGo to next message
I'm interested in that pic Grant! shanej@iinet.net.au
Re: 2TGEU in TA22: Do i need a surg tank? Wed, 04 June 2003 01:23 Go to previous messageGo to next message
If you have a later model TA22 with the upright fuel tank, a surge tank isn't necessary. I have an external VL pump in my RA23 and it's been working like that for several years with no problems. The trick is to mount the pump lower than the tank (eg in the little compartment in the boot for the jack) so it's not trying to "lift" the fuel. I have never experienced fuel surge, even with spirited driving with a low fuel level.
If you have the floor-mounted tank, you will need a surge tank though. Either that or have a swirl pot made up and use an in-tank pump.
thetoyman75
Club President
Re: 2TGEU in TA22: Do i need a surg tank? Wed, 04 June 2003 06:16 Go to previous messageGo to next message
Norbie,
Even with a pump below the main tank it really is advisable to use a surge tank. Yeah sure it will work without it to limited degree of success.
And a High pressure pump should always be below the fuel tank/surge pump that is feeding it.
Re: 2TGEU in TA22: Do i need a surg tank? Wed, 04 June 2003 06:28 Go to previous messageGo to next message
thetoyman75 wrote on Wed, 04 June 2003 16:16
I've heard this before, but no-one has been able to tell me why! Like I said, I've been running this setup for years with plenty of success. Smile
TheStitt
Membership Secretary
Re: 2TGEU in TA22: Do i need a surg tank? Wed, 04 June 2003 09:06 Go to previous messageGo to next message
I would just use a swirl pot. No smell of fumes in the boot no fuel lines in the boot and it takes up no space (virtually)
EMP-2TG
Carlingford, Sydney
Re: 2TGEU in TA22: Do i need a surg tank? Thu, 05 June 2003 01:59 Go to previous messageGo to next message
isnt a swirl pot just a surge tank but the fuel swirls around inside it?
Re: 2TGEU in TA22: Do i need a surg tank? Thu, 05 June 2003 02:19 Go to previous messageGo to next message
No. A swirl pot sits inside the tank, and is used in conjunction with in-tank pumps. It's essentially just baffling designed to keep the fuel pickup submerged at all times.
EMP-2TG
Carlingford, Sydney
Re: 2TGEU in TA22: Do i need a surg tank? Thu, 05 June 2003 02:45 Go to previous messageGo to next message
ok it goes on the fuel pump
inside the tank
http://www.vdo.com/siemens/en/prod_fuelpumps.asp
1G-GE KE35
Welly, NZ
Re: 2TGEU in TA22: Do i need a surg tank? Thu, 05 June 2003 03:30 Go to previous messageGo to next message
Norbie,
Where abouts is the fuel pickup located in your RA23, does it come out the top of the tank ??
Sam Smile
Re: 2TGEU in TA22: Do i need a surg tank? Thu, 05 June 2003 05:56 Go to previous message
Yes it does. The fuel line, fuel return line and breather line all come out the top of the tank.
Previous Topic:AVGAS FOR 4AGZE'S
Next Topic:Using Hub Extenders
Current Time: Thu Nov 19 09:54:26 UTC 2026
Total time taken to generate the page: 0.0054001808166504 seconds
