Toymods » Tech & Conversions » How do you measure cam specs?
trent_kershaw
How do you measure cam specs? Tue, 03 June 2003 05:43 Go to next message
any help will be greatly appreciated
Mr DOHC
Re: How do you measure cam specs? Tue, 03 June 2003 09:44 Go to previous messageGo to next message
u cant, u have to send it to a cam shop of machinish to get profiled
Grant
Newcastle, NSW, Australia
Re: How do you measure cam specs? Tue, 03 June 2003 22:03 Go to previous messageGo to next message
You can but to do it you must have a dial indicator, degree wheel and a set of V blocks to hold the cam. That said, still best to have a cam manufacturer do it for you.
Re: How do you measure cam specs? Wed, 04 June 2003 01:01 Go to previous messageGo to next message
well, you can measure the lift with vernier calipers, measure the base circle away from the lobe and then measure lobe+base circle and subtract to get the lift.
with a degree whell you can get a rough measurement...
you want the degree at which the lift starts and stops, and if you want to be really tricky, get a dial indicator to see when the lift gets to 1.25mm (50 thou). if you make a V out of something and bolt it down, and then have a solidly fixed bit of wire for the degree wheel, you can get within 10 deg or so... but yeah, cam place is best... let us know what $ they want to measure the profile? shouldn't be much you'd hope....
feral4mr2
Bundaberg, Qld.
Re: How do you measure cam specs? Wed, 04 June 2003 05:32 Go to previous message
http://www.club4ag.com/faq%20and%20tech_pages/4A-G E%20camshaft_story.htm
Previous Topic:4agze Head Gasget
Next Topic:Old Fords
Current Time: Thu Nov 19 13:11:22 UTC 2026
Total time taken to generate the page: 0.0059051513671875 seconds
