Toymods » Tech & Conversions » Fibreglass Bracing for bonnets ???
CheeseCake_Bandit
Illawarra
Fibreglass Bracing for bonnets ??? Wed, 04 June 2003 05:51 Go to next message
Any1 have any knowledge or know of any links that help me out in bracing down fibreglass bonnets?
toycelica77
bris
Re: Fibreglass Bracing for bonnets ??? Wed, 04 June 2003 06:03 Go to previous messageGo to next message
bonnet pins?
CheeseCake_Bandit
Illawarra
Re: Fibreglass Bracing for bonnets ??? Wed, 04 June 2003 06:16 Go to previous messageGo to next message
Let me change this then,
bracing to reduce 'flexing' eg....i'm guessing cross bars or something underneath
Re: Fibreglass Bracing for bonnets ??? Wed, 04 June 2003 06:29 Go to previous messageGo to next message
You probably need to talk to an engineer who can fabricate an alloy frame for your bonnet.
Laurie D
Re: Fibreglass Bracing for bonnets ??? Wed, 04 June 2003 08:54 Go to previous messageGo to next message
If it's a fibreglass bonnet, an easy way to brace under is to buy some polyurethane (not polystyrene) foam and cutit into strips about 30mm X 40mm X the lengths you need. Then lay them on the underside in from the edges around the perimeter, then add some more for cross bracing. Butt them neatly where they join, then fibreglass over them onto the bonnet surface. If its a steel or ali surface use epoxy resin instead of polyester. You will need at least a couple of layers of glass.
Laurie D
Youngy
Eskilstuna, Sweden
Re: Fibreglass Bracing for bonnets ??? Wed, 04 June 2003 21:25 Go to previous messageGo to next message
I agree with Laurie on his idea. If you have a look at some of the carbon bonnets getting around they use a bracing very similar to that on a standard bonnet, just made out of carbon. This then gets bonded/epoxied to the surface skin.
gold28
Madrid - Spain
Re: Fibreglass Bracing for bonnets ??? Thu, 05 June 2003 02:31 Go to previous message
Yup thats the way it's done. I used to work on plastic planes, and some of the parts were built the same way. Actually the wings were built that way, kind of.
Polystyrene is fine so long as you use an epoxy resin.
Previous Topic:3T-GTE + W55 into a KE70
Next Topic:Just a simple question
Current Time: Thu Nov 19 08:44:23 UTC 2026
Total time taken to generate the page: 0.0047829151153564 seconds
