Toymods » Tech & Conversions » 1jz servicing
supra86
1jz servicing Wed, 04 June 2003 14:28 Go to next message
how many many litre require and what oil filter recommended.
does anyone know how to change the head light bulb!!!. spent hours still dont know Thank you
Re: 1jz servicing Wed, 04 June 2003 22:42 Go to previous messageGo to next message
If it's anything like my 2JZ you'll need 4-5 litres. Use a genuine Toyota filter.
Chris Davey
sunny coast, qld
Re: 1jz servicing Thu, 05 June 2003 04:04 Go to previous messageGo to next message
if your supra is anything like my soarer, then you will need to take the side headlight out first and then remove the front one. from there it is simple. just take the little metal thing out of the back of the globe and replace with new one. and don't touch it with your fingers.
supra86
Re: 1jz servicing Thu, 05 June 2003 09:21 Go to previous messageGo to next message
but the flip up lights is so hard to get to the back, there's no space unless i take everything off (batt. etc)
what about sparks plugs should i use, thanx
Re: 1jz servicing Thu, 05 June 2003 10:29 Go to previous messageGo to next message
depends what sort of 1jz
a chaser-sump 1jz apparently takes 6 litres (!!!)
NGK bkr6es are a good spark plug for the 1jz
working from memory on my celica (which may not be the same)... if you put the pop-ups "up", and have a look on the side of them, you'll see a screw each side. take these off. then you can remove the headlight lens, and the bulb pulls straight out
STR8 2.8
Re: 1jz servicing Thu, 05 June 2003 10:32 Go to previous messageGo to next message
i noe on the ma61
u have to undo the screws on the side
the metal bracket around the light needs to come off then u just pull out the whole assembly an unplug it
some h4's just slot in the back and u r sweet
mayb a few more screws here and there
well thats what i had to do for my car neway (MA61)
supra86
Re: 1jz servicing Sat, 07 June 2003 15:34 Go to previous messageGo to next message
thanx for that,
you know where to get those spark plug cheap??
do you use mobil 1 for 1jz
supra86
Re: 1jz servicing Sat, 07 June 2003 15:35 Go to previous messageGo to next message
thank you
Re: 1jz servicing Sat, 07 June 2003 20:29 Go to previous message
depends how many kms your 1jz has done
I used mobil1 for the first oil change, but at the time it was running in limp mode (very rich), so I ended up burning a lot of the mobil 1
once I tune the microtech, I'm going to give the mobil 1 another go.. but otherwise I'll probably use penrite turbo
Previous Topic:dellow bell-housing
Next Topic:21r
Current Time: Sat Nov 21 09:58:14 UTC 2026
Total time taken to generate the page: 0.0063519477844238 seconds
