Toymods » Tech & Conversions » 1JZ Thermostat
E30-323ti
1JZ Thermostat Thu, 05 June 2003 00:30 Go to next message
Does anyone know what temp the thermostat opens on a 1JZ-GTE.
Drift pig
Re: 1JZ Thermostat Thu, 05 June 2003 06:16 Go to previous messageGo to next message
82 - 95 dude
Pete
gold coast
Re: 1JZ Thermostat Thu, 05 June 2003 11:27 Go to previous messageGo to next message
Says 82 on all that i have removed. Get a 72 degree one 1J's run heaps better when you keep them a bit cooler.
Re: 1JZ Thermostat Thu, 05 June 2003 12:09 Go to previous messageGo to next message
I always thought the 1js were supposed to run at around 90 degrees. I'm not basing this on any sort of fact.. just heresay
E30-323ti
Re: 1JZ Thermostat Thu, 05 June 2003 21:13 Go to previous messageGo to next message
Thanks for the replies guy's.
Just trying to work out on/off temps for the fan.
Pete: 72 seems really low??
Pete
gold coast
Re: 1JZ Thermostat Fri, 06 June 2003 00:19 Go to previous messageGo to next message
The only reason for high thermostats is for emissions. Anything above 70 degrees is warm enough to inhibit engine wear.
E30-323ti
Re: 1JZ Thermostat Fri, 06 June 2003 03:40 Go to previous messageGo to next message
Thats interesting.
I was going to mention it would make the stock ECU run quite rich wouldn't it.
SUPRAGTE
North Sydney
Re: 1JZ Thermostat Fri, 06 June 2003 06:44 Go to previous messageGo to next message
Sure would, it would never get out of the end of the warm up map.
You have to remember also the hotter the engine runs the more power it will produce. It's an internal combustion engine, if you run it cold it won't run effectivly and effciently.
Saying that, leave the stock thermostat and set your thermo fan at around 88-90. Are you running the normal engine fan as well?
[Updated on: Fri, 06 June 2003 06:46]
E30-323ti
Re: 1JZ Thermostat Sun, 08 June 2003 20:48 Go to previous messageGo to next message
I'm running a 14" slimline electric fan only on a custom 2row aluminium radiator.
Re: 1JZ Thermostat Mon, 09 June 2003 05:34 Go to previous messageGo to next message
how much did that radiator set you back? I'm turning into a bit of a weight nazi, so if I can save weight relatively cheaply by grabbing a new radiator, I'd love to.
E30-323ti
Re: 1JZ Thermostat Mon, 09 June 2003 20:44 Go to previous messageGo to next message
It uses a K&J dimpled 2x29mm thick core, 520x360mm.
It's $1000NZ, I also got a price from PWR over in OZ and it was $700AU.
celicamad
newcastle
Re: 1JZ Thermostat Mon, 09 June 2003 22:01 Go to previous messageGo to next message
pete im sorry but 1j thermostats are 92 degrees .OR SHOULD be im not sure what stampde on them but all teh 1j ive ever seen with a temp gauge open around 92 .
running them below this is not making more power but less .
supra gte is DEAD right i now run the Cressida at 95-100 degrees and and mid range torque has proven on the dyno plus to be ...MUCH fatter .
hotter engines do run better
and yes runing them colder makes them run rich .hot engine cold air ...now your talkin
Re: 1JZ Thermostat Tue, 10 June 2003 05:48 Go to previous messageGo to next message
right
there goes the "cheap" bit of what I was hoping for Smile
still, you get what you pay for
E30-323ti
Re: 1JZ Thermostat Mon, 23 June 2003 22:13 Go to previous messageGo to next message
FWIW
Tested the thermostat on the weekend.
It started opening at 82 as it has stamped on it.
Was fully open by 92.
Re: 1JZ Thermostat Tue, 03 May 2005 22:25 Go to previous messageGo to next message
ok, to totally raise an old thread and generally piss everyone off - with stock thermostat, what on/off should I set my thermos to?
I'm thinking on 96, off 92?
Chris Davey
sunny coast, qld
Re: 1JZ Thermostat Thu, 05 May 2005 02:13 Go to previous messageGo to next message
anyone know the answer?
I have to set mine too. I would be thinking that what Draven said is correct but some confirmation would be good Smile
E30-323ti
Re: 1JZ Thermostat Thu, 05 May 2005 05:25 Go to previous messageGo to next message
wow, this is from the dead.
I had a 92-88 thermo switch, but it was on a lot of the time with the stock thermostat.
I have put a TRD thermostat in (72d) and it is all sweet.
Skip
Re: 1JZ Thermostat Thu, 05 May 2005 07:57 Go to previous messageGo to next message
From memory my Haltech switches on at 96 off at 91 or 92.
Chris Davey
sunny coast, qld
Re: 1JZ Thermostat Thu, 05 May 2005 09:46 Go to previous messageGo to next message
thanks guys Smile
Re: 1JZ Thermostat Thu, 05 May 2005 09:50 Go to previous message
well, that was a freakishly good guess from me Smile
thanks for the input duders
Previous Topic:4age quick question
Next Topic:22mm oil resistant pipe
Current Time: Tue Oct 20 15:55:29 UTC 2026
Total time taken to generate the page: 0.0072081089019775 seconds
