Classifieds » Parts Wanted » 2T-G big cams
Jonny2TG
Tasmania
2T-G big cams Thu, 05 June 2003 13:19 Go to next message
I have a 2T-G, and I want some performace cams for it. Preferably rewelds that maintain lift, or maybe regrinds. About 290 degrees I think, maybe 304 on inlet? e-mail me if you got something.
EMP-2TG
Carlingford, Sydney
Re: 2T-G big cams Fri, 06 June 2003 01:49 Go to previous messageGo to next message
im also after the same size cams for my 2tg as well
so if anyone has 2 pairs let me know Smile
juzzo84
Hornsby, N.S.W
Re: 2T-G big cams Sat, 07 June 2003 01:40 Go to previous messageGo to next message
talk to andrew vibert, he can help you guys, he has a set of cams for sale.
justin
EMP-2TG
Carlingford, Sydney
Re: 2T-G big cams Sat, 07 June 2003 16:25 Go to previous messageGo to next message
yeah ive spoken to him
the cams he has wasnt gound properly so they anrt much good
TA22-3SGTE
MACKAY
Re: 2T-G big cams Sat, 07 June 2003 22:01 Go to previous messageGo to next message
Give Camshaft Engineering a call in Brisbane , I Had my cams reground from them an it cost me $85 including freight , That was about 8 years ago so they would be more now but at that time it was very cheep , the grind I got was 288 degree on both with .400" lift , I put these cams into a 2tg/3t hybrid and pulled a 14.8 in the TA22 .
Trevor
juzzo84
Hornsby, N.S.W
Re: 2T-G big cams Sat, 07 June 2003 22:34 Go to previous messageGo to next message
EMP-2TG wrote on Sun, 08 June 2003 02:25
what do you mean by not ground properly??
justin
EMP-2TG
Carlingford, Sydney
Re: 2T-G big cams Sun, 08 June 2003 02:09 Go to previous messageGo to next message
juzzo - it was only 1 of the 584 cams dunno what was wrong
ta22-3dgte - id love to know some specs of your old 2tg
any info would be great Smile
juzzo84
Hornsby, N.S.W
Re: 2T-G big cams Sun, 08 June 2003 05:32 Go to previous messageGo to next message
no worries man!!! thanks for that
justin
shinzui
Re: 2T-G big cams Sun, 08 June 2003 12:04 Go to previous messageGo to next message
Got a number/website for Camshaft Engineering? I looked on the net but the camshaft engineering place that came up was in WA?
CelicaRA45
nth ringwood, Victoria
Re: 2T-G big cams Mon, 09 June 2003 02:04 Go to previous messageGo to next message
tighe engineering in brisbane do hard face as does camtec in sydney and clive cams in melbourne ,also remember when you just do aregrind you will loose heaps off the base circle ,then you will have to get shims made up that are about 4mm thick ,where hard faced cam s only take off about 10thou in most cases also if the cam is 2 hot it will crap to drive so think of what you really wont cause most power wont be to 5000 if it is a 1600 with the specs you are talking about ,im running 296 duration and they are 266 at 50 thou so nothing to 5000 and thats a 2 liter 3sge engine and it goes out to 8800 rpm
andrewvibert
Forum Sponsor
Shepparton (Vic)
Re: 2T-G big cams Wed, 11 June 2003 23:39 Go to previous messageGo to next message
You have just got my memory going. When wade ground my first lot of cams they forgot to weld them first. The base circle is wrong on one of the cams. So I have good 1-584 grind cam for sale. $75 + freight. Wade can grind a mate for it. I will give you the cam that is incorrect so it can be welded and ground correctly.
andrewvibert
Forum Sponsor
Shepparton (Vic)
Re: 2T-G big cams Wed, 11 June 2003 23:40 Go to previous messageGo to next message
You have just got my memory going. When wade ground my first lot of cams they forgot to weld them first. The base circle is wrong on one of the cams. So I have good 1-584 grind cam for sale. $75 + freight. Wade can grind a mate for it. I will give you the cam that is incorrect so it can be welded and ground correctly.E mail me
juzzo84
Hornsby, N.S.W
Re: 2T-G big cams Thu, 12 June 2003 10:39 Go to previous messageGo to next message
andrew, just checking that the cams you sold me are OK???
justin
andrewvibert
Forum Sponsor
Shepparton (Vic)
Re: 2T-G big cams Thu, 12 June 2003 22:55 Go to previous messageGo to next message
No Problems with the ones you have .
juzzo84
Hornsby, N.S.W
Re: 2T-G big cams Fri, 13 June 2003 09:07 Go to previous message
thanks andrew
justin
Previous Topic:4AGE fly and extractors
Next Topic:WANTED 3t-gte engine
Current Time: Mon Jun 15 04:22:29 UTC 2026
Total time taken to generate the page: 0.0084948539733887 seconds
