Toymods » Tech & Conversions » dellow bell-housing
Ta22 20 valve
dellow bell-housing Sat, 07 June 2003 06:26 Go to next message
i have a dellow 4age to supra 5 speed bell housing
what clutch slave cylinder bolts to them they told me the t50 one does but it misses the holes by a long shot
tanman
Re: dellow bell-housing Sat, 07 June 2003 09:12 Go to previous messageGo to next message
another quality dellow product?
Bugman
Re: dellow bell-housing Sat, 07 June 2003 09:15 Go to previous messageGo to next message
welcome to the customer service that is dellows.
Re: dellow bell-housing Sat, 07 June 2003 10:17 Go to previous messageGo to next message
Interestingly, they wouldn't actually tell me which slave cylinder to use. They suggested I buy their one at $45 + $20 for the rod.
Nevertheless, I found one off a Toyota that did fit. Just had to chop the actuator rod a little. I suggest you measure the bolt centre to bolt centre distance and go to the wrecker. The one you end up using will depend on whether your slave will be mounted on the driver's side or the passenger's side.
Then never buy from them again.
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: dellow bell-housing Sat, 07 June 2003 11:40 Go to previous messageGo to next message
My T50 slave cylinder fit onto my supra/4age Dellhousing, it was the jap T50 with the cylinder on the drivers side though.
Otherwise it is a fairly universal cylinder, 30 or so bucks from your local clutch place should do it.
Re: dellow bell-housing Sat, 07 June 2003 12:55 Go to previous messageGo to next message
Ahhh.. The Mighty Dellhousing Co. demonstrates killer customer service again! Their 'rod' is actually just a hardware store bolt pretty much.. nothing too flash! Just get the common cylinder that bolts on whichever side of the housing you need, and make your own rod (takes 2 minutes in a lathe, should be quite doable without though) Yes, that clutch fork is a killer...
Did you remember to shorten the bearing 'carrier'?
Ta22 20 valve
Re: dellow bell-housing Sun, 08 June 2003 00:48 Go to previous messageGo to next message
thanx for the replies
yeah but what Toyota did ya get the slave cylinder off in aus. its on the passenger side
Re: dellow bell-housing Sun, 08 June 2003 00:59 Go to previous message
I actually used a Corona Mk2 one with a cut down pushrod from an ST141 (JZ-W58 bellhousing). I can't guarantee this will fit yours as I don't know your bolt centre to bolt centre spacing.
Previous Topic:What were ther non platnum 1JZ-GTE spark plug coads again!!!!
Next Topic:1jz servicing
Current Time: Sun Jun 14 02:35:22 UTC 2026
Total time taken to generate the page: 0.0093741416931152 seconds
