Toymods » Tech & Conversions » GZE SC problems
Gremlin
Maroubra
GZE SC problems Thu, 27 June 2002 04:12 Go to next message
hey guys
is there any way that the SC can just stop working on a 4agze... cause i think mine has... it just doesn't seem to pull anymore...
it only happened since i removed the dead battery and re-charged it...
any help would be great
whiteGZE
Western Sydney
Re: GZE SC problems Thu, 27 June 2002 11:50 Go to previous messageGo to next message
The computer triggers the operation of the SC. Perhaps there is a bad connection that's stopping the sc clutch from engaging. There could also be a fault in the sc relay.
Are you sure the sc is not working? Have you got a boost guage? There could be many reasons why you have less power such as boost leaks, slipping belt, knock sensor, abv etc.
Darola
Taree, 4h nth of syd
Re: GZE SC problems Thu, 27 June 2002 16:03 Go to previous messageGo to next message
hey there, can u tell us more on whats it doing, im trying to think off whats it doing, what engine is it?? ae 92 or 101
r u running standard computer?? how long was the battery left out of the vehicle?? did it spark as u re-connectd the battery??
Gremlin
Maroubra
Re: GZE SC problems Fri, 28 June 2002 03:02 Go to previous messageGo to next message
it's an AE92 AFM. standard ecu... no boost guage:( (yet) and i can't remember if it sparked
the battery was out for about 2 days max...
the bloody thing sounds like a lawnmower... maybe it just really needs a tune.. but it was never this bad...
it's been garaged for a while now as is unreg. i've been trying to get it ready for blue slip but i can't take it like this... and i can't afford towing to a mechanics to get an opinion...
damned if you do, damned if you don't!!!
to be honest it sounds as though it's running on 3 cyl.
i checked the leads and they seem fine... i lent my tools to a mate so i can't check the sparkies yet Sad
when idling, there is a fairly strong smell of petrol.
hope that helps!!!
please keep me posted Smile
[Updated on: Fri, 28 June 2002 03:10]
Darola
Re: GZE SC problems Fri, 28 June 2002 07:25 Go to previous messageGo to next message
hey bro, my mate and i might be able to make it around on the weekend to help u check it out
Eddie (Darola)
Gremlin
Maroubra
Re: GZE SC problems Fri, 28 June 2002 09:09 Go to previous messageGo to next message
that would be great...
however, i work in the mornings...
should be home by 2 pm though...
if you can't make it then, don't worry... that's cool
i'll send you a msg with my number if you still want to come
Darola
Re: GZE SC problems Sat, 29 June 2002 01:39 Go to previous messageGo to next message
hey gremlin, give us a ring as soon as u can and we will come for a cruise over
call on 0414 530 680, 0412 376 020
Eddie (Darola)
GT4_Steve
Sutherland, Sydney
Re: GZE SC problems Sat, 29 June 2002 01:51 Go to previous message
Hey Gremlin,
I think the reason you are not getting any pull from the SC is due to the fact that the engine is not firing properly and is unable to sustain and power int eh upper rev range. If you have dropped a plug or something then that would explain the lawn mower feel to it and probably the strong fuel smell.
I personally would inspect all your plugs and sparks...and get a socket to your exhaust manifold nuts and make sure they have not gone loose on you.
Previous Topic:Starting gze conversion to AE82
Next Topic:RWD 4A-GZE Block only, Water Pump/Thermostat
Current Time: Wed Nov 4 20:53:16 UTC 2026
Total time taken to generate the page: 0.039368152618408 seconds
