Toymods » Tech & Conversions » another "what supra box do i have?" question.....
gabe
icon10.gif  another "what supra box do i have?" question..... Sun, 08 June 2003 12:06 Go to next message
i just bought what i thought was a w58 supra box. now when i got home i counted the ratio in 5th. 10 turns in gives 11.75 out. so would this indicate that the box i have is a w55?? and yes it definately does have an alloy casing and a STEEL sandwich plate.
is this an x-file??
any help is appreciated
gabe
gabe
Re: another "what supra box do i have?" question..... Sun, 08 June 2003 12:36 Go to previous messageGo to next message
just did some research on the net and found out that there is infact a w59.....
the ratios are
W55 -4.091 3.566 2.056 1.384 0.861 35kg
W57 -3.768 3.285 1.894 1.275 0.861 35kg
W58 -3.768 3.285 1.894 1.275 0.783 35kg
W59 - ? 3.954 2.142 1.275 0.850 35kg
the site says that the w59 was used in trucks etc.
has anyone heard about this box??
i know the ratios are not very good (the overdriven 5th was one of the reasons i wanted a 58)
[Updated on: Sun, 08 June 2003 12:38]
Re: another "what supra box do i have?" question..... Sun, 08 June 2003 12:52 Go to previous messageGo to next message
10/11.75 ~ 0.85
10/11.61 ~ 0.861
10/12.75 ~ 0.78
Don' take offence, but did you count every turn? Might pay to double check. Use a texta to set some reference marks on the input and output shafts.
Also check first gear.
[Updated on: Sun, 08 June 2003 12:54]
ed_ma61
Lost in the K hole
Re: another "what supra box do i have?" question..... Sun, 08 June 2003 13:03 Go to previous messageGo to next message
w59 can actully be a not bad box if used in combination with a 3.712 diff ratio (or there abouts)...
well, yeah, depends on the engine you want to gear it onto, but for a 7m at least, a w55 or w59 with a 3.712 came up quite nicely.
and yeah, w59 isnt that common, but theyre out there..
ed
ed_ma61
Lost in the K hole
Re: another "what supra box do i have?" question..... Sun, 08 June 2003 13:04 Go to previous messageGo to next message
and yeah, ive had a few glasses of red... ok
and yeah...
so, um, yeah...
gabe
Re: another "what supra box do i have?" question..... Sun, 08 June 2003 14:29 Go to previous messageGo to next message
GT,
yeah i did count every turn, its definatley 10 in and 11.75 out
but i will recheck tomorrow (also first gear)
ED,
i am planning on using a g series hilux LSD diff as i have one lying around. its ratio is 4.3, am i right in thinking that that combo will be a pain in the poop chute??
gabe
ed_ma61
Lost in the K hole
Re: another "what supra box do i have?" question..... Sun, 08 June 2003 14:48 Go to previous message
gabe wrote on Mon, 09 June 2003 00:29
not if youre planing on using it in a tractor Rolling Eyes
id be stting down with a calculator if i were you. look at your engines power band, then calculate your final drive ratios for different box/diff combinations.
see what suits the engine and your driving habits.
ed
Previous Topic:LSD Diff
Next Topic:what brakes on ke30
Current Time: Fri Nov 20 07:09:58 UTC 2026
Total time taken to generate the page: 0.10955786705017 seconds
