Toymods » Tech & Conversions » AE92 electrical gremlins
AE92 electrical gremlins Sun, 08 June 2003 13:39 Go to next message
Does anyone happen to know of a great place to start looking for electrical nasties on an AE92? This is a standard car, 4AFC, 3 speed auto (yick!). I know of a few common problems on some cars that can do funny things with the electrics (e.g. earth wire on headlight of R31 skyline), but not the AE92... The trouble is it will suddenly decide to stall as well as moving the temp gauge to the max position (no, it's not overheating, it's an electrical problem..). Can someone PLEASE save me from farting around for hours with a multimeter trying to look for crook earthing etc.?? Evil or Very Mad
juzzo84
Hornsby, N.S.W
Re: AE92 electrical gremlins Mon, 09 June 2003 01:10 Go to previous messageGo to next message
check the earth on the gearbox, they are often a part that comes loose.
justin
Re: AE92 electrical gremlins Mon, 09 June 2003 01:12 Go to previous messageGo to next message
Yeah it has to be a bad earth. Its always a bad earth Rolling Eyes
Scorpion
Menai area of Sydney
Re: AE92 electrical gremlins Wed, 23 July 2003 13:47 Go to previous messageGo to next message
I'm getting the same problem that you by the sound of it. Doing all the usual diagnostics etc and it seems to be related to some sort of thermostat issue. When idling, the temperature sometimes rises and falls like a thermo cutting in and out. Often stalls on idle which becomes first sign it will play up after driving OK. Tapping accelerator pedal makes the needle drop down and back up, driving brings needle nback to normal sometimes. I thought it might be the auto choke coil which is the only thing I can see with a wire hanging out of it which might get affected by the slightest tap on the accelerator peddal. Did you get to resolve your issue ?
Re: AE92 electrical gremlins Fri, 25 July 2003 02:46 Go to previous messageGo to next message
You're the one that emailed me right?
sideshow
Re: AE92 electrical gremlins Fri, 25 July 2003 05:57 Go to previous messageGo to next message
on ae92 the temp gauge has an earth wire to it
if this earth aint hooked up it reads hi off the gauge
the earth wire (brown) runs thru the yellow plug which is below the stereo on left hand side
these wire run thru the firewall to the engine and earths on the block
and the idling stalling prob could be due to idle or fuel cut solenooid havin no earth
so check to se eif that brown wire and the wires on the carby have an earth
Scorpion
Re: AE92 electrical gremlins Fri, 25 July 2003 06:05 Go to previous messageGo to next message
Correctamundo.
Scorpion
Re: AE92 electrical gremlins Fri, 25 July 2003 08:22 Go to previous message
Thanks Sideshow. Mr Shin gave me some tips on earthing wires from the loom to the inlet manifold and I have cleaned up an earth wire from the inlet manifold to the drivers side strut tower. Problem sems to be resolved but I will follow up on the temp gauge brown wire on the weekend to make doubly sure. Cheers.
Previous Topic:ATTN: ST205R Owners
Next Topic:Under bonnet lining
Current Time: Fri Oct 2 04:38:56 UTC 2026
Total time taken to generate the page: 0.13726806640625 seconds
